UPDATE: 2/2/15
With my new power supply this is able to heat up to 110C in 10 min. Pretty fast with the heavy boro glass and the aluminum heat spreader. Overall I'm really satisfied with it.
6061 T6 Aluminum Build Plate .190" Thick
Custom Build Plate to make a heated silicone heat bead 300mm x 300mm.
Plans also include a .063" heat distribution plate
DXF Files Available
12.5" x 12" Assembled Heated Build Plate
Build in 'Everything Else' published by wesner0019, Feb 2, 2015.
Custom build plate for 300mm x 300mm (12"x12"). The hole pattern is for the 20x60 V Slot
Build Author wesner0019, Find all builds by wesner0019
Qty Part Name Part Link Comments 1 6061 T6 Aluminum 12.5" x 12.0"x.190" Plate https://www.midweststeelsupply.com/store/6061aluminumsheet Link ~$15 1 6061 T6 Aluminum 12.5" x 12.0"x.063" Plate https://www.midweststeelsupply.com/store/6061aluminumsheet Link ~$13 1 12" x 12" Silicone Heat Bed http://store.quintessentialuniversalbuildingdevice.com/pr... Link ~$65, 12V, 20A 1 300mm x 300mm Borosilicate Glass https://www.lulzbot.com/products/borosilicate-glass-bed-3... Link ~$50 1 Permatex 81878 Ultra Copper Maximum Temperature RT http://www.amazon.com/gp/product/B0002UEOPA/ref=oh_aui_de... Link ~$7, Used to glue heater onto .063 aluminum heat distribution plate 1 12"x12"x1/4" Cork Board http://www.amazon.com/gp/product/B0018DHBAK/ref=oh_aui_de... Link ~$6, Used for insulation between the build plate and the heater -
