I have the demand to cut/etch tall pieces of material. For this reason, I have designed a machine with 500mm uprights with adjustable gantry height. This way I can raise/lower the sled and z-axis as needed. I've also chosen to use a linear C-channel assembly for the Z axis with the plate mounted to the gantry instead of the other way around. This will allow for maximum range of the z-axis. The parts list/BOM does not include motors/belts/pulleys or electronics. - More to come soon!
1500x1000mm Adjustable Height
Build in 'Cartesian Style CNC' published by JerryD, Jul 9, 2017.
Build Author JerryD, Find all builds by JerryD
Mostly Cutting wood and plastics. Ability to cut taller materials, potentially laser etch in the future. Ability to cut plates for future builds!Inspired by
Metalguru's C-Beam 750, The Hoss, Batxillerat Research Project, ROUTY CNC Router (V-Slot Belt & Pinion) -
