BlackBox Motion Control System v 2.7
24V Meanwell Power Supply Bundle
NEMA 23 Stepper Motor (x2)
C-Beam® Linear Rail
mounted to custom acrylic base with custom mounting plate to hold mini vise for mounting blades.
2 Axis Lathe cutter
Build in 'Other Lathe Build' published by Nick Cipolla, Jul 11, 2022.
Rubber company use as a lathe cutter for accurate cuts compared to hand cutting.
looking to add the INTERFACE CNC Touch into our system along with liquid coolant dispenser near the blade.
ArthurS, Ted Moyer, David the swarfer and 3 others like this. -
Build Author Nick Cipolla, Find all builds by Nick Cipolla
Small rubber company lathe cutting tubingInspired by
attempting to upgrade from hand cutting parts to get more accuracy. -
