This is my latest project, a new CNC router with a larger cutting envelope (1500mm x 3000mm / approx 5 by 10 ft) and strong enough to cut wood and aluminum constructed from a mixture of 20-series extrusions in the frame (from OpenBuilds) and some 40-series extrusions (in the gantry) from 80/20.
Here's links to a couple of videos that I took while calibrating. (You can see my build log for more)
Z-Axis: https://photos.app.goo.gl/sXxNwl731n0L1g8x1
Y-Axis: https://photos.app.goo.gl/hzHeRSk8Lj1raUh23
Initial Checkout: https://photos.app.goo.gl/5zsYLl3gG2OKgr7m2 (Linear gears not yet lubricated or tuned in this video)
NEWEST UPDATE: (SEEKING OPINIONS FOR A SPINDLE REPLACEMENT)
UPDATE 2018-01-10 - The project is pretty complete at this point.
- Everything is wired up and the machine is working with Mach3, although I still need to add some limit sensors. I've simply been waiting for it not to be 5 degrees in my workshop to do it!
- I've also been thinking about whether to invest in a new spindle such as one of those cheap chinese models to replace my SuperPid-enhanced Bosch 1617EVS router... perhaps something in the 2K to 5K horsepower range... does anyone have any opinions about that?? At some point I'd like to make or buy an automatic tool changer and I'm wondering what (affordable) spindle I could get that might be compatible with that idea.
Want to See More?? You can see more of this machine along with lots of photos and commentary in the project log which goes into more depth regarding the various aspects of the build, issues encountered in building and whatever else is going through my mind at the time.
- One last major item-- okay, two items, but they're related. One is to put together a complete documentation package on the machine which will include CAD drawings, Bill of Materials, electronics / wiring schematics, and detailed notes on setting up / configuring Mach 3. The other item is to completely re-make all of the manually fabricated parts using the machine itself using the CAD drawings to obtain more precision.
Project Log: https://goo.gl/photos/Co81AvGwVijE2zow9
OLDER UPDATES:
2017-11-07 - Added last essential fabricated piece and mounted router spindle. Now the focus is turning to getting everything wired up and rebuilding the control electronics enclosure. The machine is not quite finished yet but is getting very close now. I'm at around the 90-95% point with the wiring and rebuilding the control electronics as the major outstanding items to complete.
2017-10-22 - REACHED A MAJOR MILESTONE!!! I am able to see light at the end of the tunnel. All of the major framework is complete, the gantry is built, and the motors are attached. For the first time since I started, it feels like this thing might actually work!!
2017-09-12 - Construction underway. I have constructed the gantry, added the X-axis rails and the project is moving along.
Build #2 - Bigger & Stronger
Build in 'X/Y Table Style CNC Mill' published by JWhitten, Jan 11, 2018.
Large format CNC router with a 1500mm x 3000mm cutting envelope (5 x 10 ft) strong enough to cut wood and aluminum constructed from 20-series and 40-series aluminum extrusions. Complete Project Log w/ Pictures: https://goo.gl/photos/Co81AvGwVijE2zow9
I have added a list detailing the primary parts and suppliers I've used at the bottom of my Project Log. While not an actual BOM, it provides a reasonably complete accounting for the parts.
wang hsiang-ping, phil B1 ken ob, Patrick Cnadler and 13 others like this. -
Build Author JWhitten, Find all builds by JWhitten
I needed a CNC router which can cut larger sheet goods as well as one which is stronger and stiffer that can better cut metal (aluminum, etc)Inspired by
Obviously the OX, and countless other CNC projects on the web. I also built my own version of the OX which you can see in many of the photos, as well as the build log which is also on this site.
