I decided to double the size of the standard c-beam package and this is that project.
Size enlarged to 1000mmx1000mm. Extending the sides and back to the 1000mm extruded aluminum.
Bear in mind, you will need a solid worktop of at least 42"x42" for this build. You need to make a space for this first or you may run into space constraints issues.
I built my base out of treated 2x4 lumber, 3/4" mdf flooring as a top base with 1/2" mdf over that.
The only issue I ran into was that I enlarged the work surface as well. I decided to go back to the 12"x12" and as suggested I will add taller spaces on the gantry plate so I can go beyond the Y axis stepper to fully utilize the project base.
I will update and add pics and videos later if possible.
My first cuts
As you can see I tested the wrench file on this scrap mdf, also wanted to do a test run of the Open Builds Logo.
C-Beam 1000mmx1000mm
Build in 'X/Y Table Style CNC Mill' published by Charles Roseberry, Apr 18, 2016.
C-Beam basic package doubled in size.
Paul Stoller, snokid and GrayUK like this. -
Build Author Charles Roseberry, Find all builds by Charles Roseberry
I wanted to get into the world of hobby cnc and make items for sale or friends, etcetera.Inspired by
I admired the site for C-Beam Open Builds and Tracy Ranson was a great help and an inspiration for the build. -
