Facebook discussion:
D-Bot / C-Bot Core-XY 3D Printer Group
This is a Core XY, not an H-bot printer, but the two are based on the same principles for motion.
I designed this with a couple goals in mind:
-not to use any linear rod/bearings; I used V-slot for all guided motion
-no crossing belts as found in most core XY printers; I used two offset parallel belt runs
-run the belts through the extrusion when possible for a cleaner end product
-make the entire setup easily modifiable and adaptable so others can use it for alternate bed sizes
(I am using an 8x12, but changing to an 10x10 or 12x12 is as easy as cutting your extrusion to different lengths, no part redesign required)
Extrusion Length Calculator (Rework): C-Bot Cut Calc <--Also available in the excel BOM
Please let me know if I forgot anything or there are errors.
Check out this excellent build blog by AK Eric, which covers both the original build and front/rear lead screw modification:
C-Bot 3D Printer
Check out this very well documented remix that covers the offset lead screw configuration and has an amazing detailed build guide (useful for whatever version you are building):
D-Bot Core-XY 3D Printer by spauda01
Adamcooks 3 Lead Screw Option:
Triple C-Bot | OpenBuilds
Collection of Other Parts:
C-Bot: A Collection by cfeniak
HotEnd Mount Generator:
Hot End Mount Generator - Customizable for various carriages, hot ends and options. by croadfeldt
GitHub - croadfeldt/Roadfeldt_3d_hczf_mount: Parametrized Hot / Cold End, Print Cooling Fan, Z Probe, Servo Mount for various X carriages.
C-Bot
Build in 'H-Bot and Core XY' published by Carl Feniak, Feb 21, 2019.
A robust Core XY style 3D printer that has a clean parallel belt implementation and whose dimensions are adaptable to meet builder's needs. The use of open builds V-slot and other open hardware make customization easy.
Ygyg, mds58, jhardy1979 and 73 others like this. -
Build Author Carl Feniak, Find all builds by Carl Feniak
I had built Wired1's OB1.4 (http://www.thingiverse.com/make:61372) and wanted the challenge of designing my own printer. Thought the H-bot movement concept was really cool and gave it a try. Then decided to move on to utilize the benefits of CoreXY.Inspired by
All open source H-Bot and Core XY printers I've come across (there are lots out there) -
Qty Part Name Part Link Comments 1 Bill of Materials Link See BOM in attached Excel File -
