This build is based on the c beam mill but using standard avaliable parts in Germany.
It's tough to get c beams so i designed it to use 20x20 and 20x80 Profils for the actuators
The end mounts are currently printed parts until I have proven my concept they will be replaced by metal parts hopefully milled on this system
Electrical Components
So i have looked into 2 different options to set up my controller for the CNC.
1. Arduino Uno R3 mit CNC Shield
I flashed the current GRBL 1.1 Version on to the Arduino Uno and connected it to the digital stepper drivers as displayed below
Credit -> http://dfsimg.hqew.net/group3/M00/45/86/wKhk7VwSD-uAInCQAAGCca-mm1M006.jpg
Intitaly i had a Problem on connecting the arduino to the USB solution for this is the driver called CH340 after that connection was going with out a problem.
2. Keyestudio CNC Grbl v0.9 board - Not a good option as it runs GRBL 0.9 and is not supported by openbuilds control
I have designed a case for the board as it didn't come with one.
The board works out of the box with the openbuilds controls that i have so far tested.
What i am still waiting on are drivers which i need to mount on the board to rig up the wiring of the nema 23 motors.
I have a single 12 V input but unfortunately no indicator with how many Amps. so iam a bit worried that the motors will not get enough juice from the board to work correctly (pls feel free to correct me on that.)
Looking back at the OpenBuilds C-Beam partslist they actually have a 24V Power Source so this is going to be intressting. Nice thing is you can control Spindles and Lasers with the same board and it is equipped to handle E-Stops as well
New Keyestudio CNC GRBL V0.9 Board for CNC/Laser engraving
Cnc Mill using standard and 3d printed cimponents
Build in 'X/Y Table Style CNC Mill' published by TRMA-Chaser, Sep 20, 2019.
I used the cad designs for the c beam to find a solution to my initial sourcing problem. I figured that I could use 2x 20x20 and 1x 20x80 Profil to create a c beam actuator. I sourced all of the profiles from a local machin builder and t-nuts and screws in my local hardware store. Some parts are currently in 3d printed pla for testing reasons.
YOSEF MELKA, Metalbender and Mark Carew like this. -
Build Author TRMA-Chaser, Find all builds by TRMA-Chaser
Qty Part Name Part Link Comments 1 Keyestudio-cnc-grbl-v09-board-for-cnc-laser https://keyestudio.com/new-keyestudio-cnc-grbl-v09-board-... Link -
![IMG_20190918_210434[1].jpg](data/attachments/41/41972-9e354e6e48ab53db7f7daaff4cd8c036.jpg)
![IMG_20190918_210450[1].jpg](data/attachments/41/41973-2acccdc12d3b17210dbbb808bff0e42c.jpg)
![IMG_20190918_210450[1].jpg](data/attachments/41/41974-2acccdc12d3b17210dbbb808bff0e42c.jpg)
