Dash-X is a Cartesian 3d printer, the third major evolution of this design. Having tried both HBot and CoreXY, I am currently of the opinion that the best results derive from machines with isolated X, Y and Z axes.
This design utilizes a cross-beam drive, similar in concept to the Ultimaker but beefier. It makes heavy use of Openbuilds wheels and V-Rail -- in fact there are NO linear bearings whatsoever.
The speed and quality of this printer have proven to be very good, significantly faster than the Creality products (which I like quite a lot).
I am posting the Solidworks Pack-and-Go file and a zip file containing all of the IGES files. If you require one or more STL or 3MF files let me know. Also please find a zip file with customized Marlin 1.1.9.
There are several purchased items, links are provided here as well.
Questions: Click HERE to email me.
Note: in the video I call the rotary shafts "fiberglass". That's incorrect, they're actually solid carbon/graphite fiber shafts. They are properly linked in the parts list.
Build in 'Cartesian Style Bots' published by Neil Rosenberg, Mar 21, 2020.
This is NOT a project for a rank beginner. Also you will need access to a well-functioning 3d printer to make the parts.
The belts I used are Gates Powergrip GT2 2mm. These are a significant upgrade from the typical no-name belting: less running friction, reduced riding-up on pulley flanges, superior tensile properties, more flexible.
Wudbutcher, Waynewwc, Hans Petter and 49 others like this. -
Build Author Neil Rosenberg, Find all builds by Neil Rosenberg
Most recent version, vying for best print quality and highest speed. So far, so good!Inspired by
Hot end carriage inspired by: Creality CR10S Pro Hotend mount and Part Cooling + BLTouch mount by Hangtight -
