Based on the Delta 6, @Jerry426 created a new design that is stiffer and has a lot of modified parts. I have decided to rebuild my old WolfStock printer into this modified Delta 6 design.
Parts are printed in PolyMax PLA ( vertexes ), HatchBox PLA+ ( magenta parts ), and eSun PETG.
Delta-Six ( Jerry426 variant )
Build in 'Delta Bots' published by Martin Bogomolni, Sep 30, 2016.
Building a Delta-6 variant, using recycled parts from a WolfStock Delta printer.
TouchPadKing likes this. -
Build Author Martin Bogomolni, Find all builds by Martin Bogomolni
Need a large Delta printer with a build area ~300mm in diameter and ~400-500mm tall.Inspired by
Delta-6 w/ Jerry426 Mods -
Qty Part Name Part Link Comments 3 Vertex tall Link 3 Vertex small Link 60 M5 X 10mm Cap Head Bolt http://openbuildspartstore.com/low-profile-screws-m5/ Link Alternative link : http://www.amazon.com/dp/B00DD4V9SM/ref=biss_dp_sa1 3 V-Slot 20X40 @1000mm http://openbuildspartstore.com/v-slot-20-x-40mm/ Link These form the towers. You can also use 1500mm and cut it down to size 9 V-Slot 20x40 @500mm http://openbuildspartstore.com/v-slot-20-x-40mm/ Link These form the sides - two on the bottom, one on the top 60 M5 T-Nuts http://openbuildspartstore.com/tee-nuts-25-pack/ Link 12 M5 x 30mm or 40mm Hex Cap Bolt http://openbuildspartstore.com/low-profile-screws-m5/ Link Alternative link : http://www.amazon.com/dp/B00DD4V9SM/ref=biss_dp_sa1 0 M5 x 0.8mm Tap http://www.amazon.com/Vermont-American-21123-5MM--80-Carb... Link Use this to tap both holes in the ends of your short V-Slot sections -
