My first printer was a Voxel OX from this site. Its been running for two years and I have been thinking about a large delta build. For stability I wanted no plastic parts in the frame. I have followed other builds and for this size printer most are using materials custom cut on a CNC or water jet. I could not justify a $20 13" x 13" x.125 build plate being custom cut for $150. My top and bottom plates together cost $40 and would have cost another $200 to have them professionally cut. So the basis of my build is to cut all of my materials myself and use drill jigs to give me the necessary accuracy for this build. My tools include a 12" radial arm saw, a 10" table saw, a jig saw and a scroll saw, along with a drill press and misc. hand tools. Right now I am in assembly having cut my plates and just received the v-slot materials. The total out of pocket costs for the frame material excluding freight is less than $200.
Delta without vertices
Build in 'Delta Bots' published by Craig Anderson, Jul 1, 2018.
As this is a build in progress, I will update it as I progress.
Props go out to OpenBuilds Member Ryan Lock as well as OpenBuilds Team member Matt who worked up these great build log videos. The entire OpenBuilds Community is to be thanked for all the great collaborative ideas that makes builds like this possible.
Mark Carew and CNCKitCompany like this. -
Build Author Craig Anderson, Find all builds by Craig Anderson
The WorkBee is a great example of what can be done with the OpenBuilds system. So we worked in some changes for production and are happy to make it available to community.Inspired by
The original Ooznest WorkBee by Ryan Lock -
