The k40 CubeThe k40 cube is an interesting build based on using the same technology and stock parts from the cheap Chinese k40 machine, this build also allows to grow in size in the feature by just modifying the X Y Stage using the V-SlotĀ® Mini V Linear Actuator system and a Smoothie or GRBL control board, after completing my previous build of the Franken40 many parts and machines were around my garage just doing nothing so a spare k40 and an Acro system machines were used to start this build.
Another Franken 40
K40 Cube Laser Cutter
Build in 'Laser Cutter Builds' published by pedrofernandez, Jan 9, 2019.
The k40 cube is a laser cutter build using mostly stock parts of the chinese k40 laser
retoled rotulos, Parinya Chatwararat, Les1973 and 5 others like this. -
Build Author pedrofernandez, Find all builds by pedrofernandez
to achive a 12x12 cut area with the same motion system of the k40 macineInspired by
Previous build of the Franken40
