Hello everyone!
Exciting news! We’re proud to introduce the PLASMA Add-On for our versatile LEAD 1010 CNC Machine. This add-on isn't just an accessory; it's a new way to ignite your creativity, allowing you to explore both wood and metal with the same robust precision.
Embrace the power to create stronger, more intricate projects. We're just beginning to tap into the potential of this add-on, and we can’t wait to see the innovative metal works you'll bring to life. Let’s keep pushing the limits of what we can build and share. Keep inspiring and keep creating!
#openbuilds
LEAD 1010 PLASMA Add-On Specs:
Dimensions
* NOTE: The actual material thickness penetration may vary depending on the plasma cutter used, with most cutters capable of cutting approximately up to 3/4" thick material.
- Max Travel on Z axis (Up and Down) - 80mm (3”)
- Max Travel on Y axis (Front to Back) - 830mm (32 ½”)
- Max Travel on X axis (Side to Side) – 740mm (29”)
- Material Thickness – Has clearance for materials up to 25.4mm (1”) thick*
Materials this machine can cut.
Plasma cutting can be performed on any tyle of conductive metal.
Virtually any metal can be plasma cut including steel, stainless steel, aluminum, brass, copper, etc. Any thickness from 30 gauge through 13/16" can be cut, depending on the power of the plasma cutter being used.
- Steel
- Stainless Steel
- Aluminum
- Brass
- Copper
1 INTRO VIDEO:
- Convert your LEAD 1010 CNC into a Metal Cutting Monster!
2 Assembly VIDEO:
- Jump in and when you complete this easy and fun step by step build-along videos you will have an awesome 3 Axis PLASMA cutter for your workshop!
3 FIRST CUT VIDEO:
- Let's make your first cut and project!
SOFTWARE:
OpenBuilds CAM - [LINK]
OpenBuilds CONTROL - [LINK]
- For creating 2D drawings, we use Free Inkscape or any vector based program, even a 2D CAD program will work if it can export SVGs or DXFs.
- the Free and Awesome OpenBuilds CAM
(CAM Works up the cut lines and makes the G-code for the parts)- For controlling the machine, we use OpenBuilds CONTROL Software
(CONTROL Reads the G-code created in CAM and moves the machine to make the part or art)
Helpful References for Plasma Cutting:
Features / What is Included
We include all the necessary Parts to convert your LEAD CNC 1010 to be capable of plasma cutting.
- Lift kit – Lifts the machine from the frame 60mm (2 ¼ “)
.- Floating Z Head - Floating Z axis torch holder
.- Torch probe - Material start height surface probe.
.- Universal Torch Holder – Hold and swap out bent and straight torches between 30 and 40mm (1 1/8th – 1 ½”) in diameter.
.- Slat Holders – Mountable galvanized slat holders hold up to 15 table slats.
.- Table Slats – 15 reversible 16 GA table slats.
.- Hard Stops – Slot mountable rubber hard stops for all axes.
.- All the hardware required to assemble and attach the Plasma Add-On
*NOTE: Plasma Cutter/Torch, Optional Water Tray and accessories are not included
Optional Recommended Accessories:
After extensive research and testing on these products, we share our recommendations through our affiliate links. We're providing you with a starter setup that includes the plasma torches, air compressors, and water trays we use. You'll also find other optional accessories that might interest you as you expand your plasma system to meet your specific needs.
- Air Compressor: https://amzn.to/4akn0lr
- Water Pan: https://amzn.to/3xnG8jP
- Plasma Cutter: https://amzn.to/3J8Sgrz
- Straight Torch: https://amzn.to/3W9vsPV
- Starter Pack: https://amzn.to/3PKgMCP
- Glasses: https://amzn.to/3POXWuo
- Thickness Gauge Guide: https://amzn.to/4aIjFMA
- Burr Bit Set: https://amzn.to/3PS05Wq
- Grinder: https://amzn.to/49kdrRX
- Enclosure Box - Amazon.com
- Dust Mask - Amazon.com
NOTE: As an Amazon Associate, OpenBuilds earns from qualifying purchases and we appreciate your support!
Works with many torch sizes:
Universal Torch Holder – Hold and swap out bent and straight torches between 30 and 40mm (1 1/8th – 1 ½ ”) in diameter
LEAD Plasma Gallery:
- OPEN SOURCE - The LEAD CNC machine is Open Source, and the Builder community is encouraged to modify and build on this design.
PROJECT:
CUSTOMIZATION - Take it to the next level and make it your own!
Share your builds with the Open-Source Builders community OpenBuilds.com
Wrench Guy - Hang It Project
Build in 'OPENBUILDS MACHINES' published by OpenBuilds, Apr 26, 2024.
LEAD 1010 PLASMA Add-On is a great modification you can do for your LEAD 1010 to convert it into a metal cutting monster machine!
Always innovating and looking to create solutions for Makers!Inspired by
LEAD 1010 CNC -
Qty Part Name Part Link Comments 1 LEAD CNC 1010 Plasma Add-On https://openbuildspartstore.com/lead-cnc-1010-plasma-add-on/ Link PLASMA Addon bundle for the LEAD 1010 1 Air Compressor https://amzn.to/4akn0lr Link Optional Accessories 1 Water Pan https://amzn.to/3xnG8jP Link Optional Accessories 1 Plasma Cutter https://amzn.to/3J8Sgrz Link Optional Accessories 1 Straight Torch https://amzn.to/3W9vsPV Link Optional Accessories 1 Starter Pack https://amzn.to/3PKgMCP Link Optional Accessories 1 Glasses https://amzn.to/3POXWuo Link Optional Accessories 1 Thickness Gauge Guide https://amzn.to/4aIjFMA Link Optional Accessories 1 Burr Bit Set https://amzn.to/3PS05Wq Link Optional Accessories 1 Grinder https://amzn.to/49kdrRX Link Optional Accessories -
