Hi All -
These aluminum MagBall carriages are designed for the UltiBots K250 V-Slot and Mini Kossel DeltaBot 3D printers using Open Builds V-Slot aluminum. They were machined using a C-Beam CNC Router.
See gallery images and details below.
Brad - www.UltiBots.com
Modified C-Beam Bundle
Dewalt 611
Elaire 1/8" Collet
1/8" Single Flute Carbide End Mill
Workflow = Fusion 360 & Cam > Chilipeppr > Tinyg
RPM ≈ 25,000 (dial setting 5)
Feed @ 20"/min (508mm/min), Ramp @ 5"/min (127mm/min), Plunge @ 8"/min (203.2mm/min)
Pocket cut = 0.25mm rough & 0.2mm finish, 3mm max stepover
Bore cut = 0.2mm pitch
Contour cut = 0.25mm rough & 0.2mm finish
Machined Aluminum MagBall Carriages
Build in 'Delta Bots' published by UltiBots, Jun 18, 2016.
Brian Huff, M98Ranger, MaryD and 5 others like this. -
Build Author UltiBots, Find all builds by UltiBots
