CNC Hot Wire System that cuts EPS and XPS foam. Lathe, Turntable and 4 Axes Cutter
Massive Hotwire Foam Cutter
Build in 'Everything Else' published by Jymmiee, Mar 22, 2020.
CNC Hot Wire Foam Cutter. Lathe, Turntable and 4 axis Cutter. Can cut XPS and EPS.
Build Author Jymmiee, Find all builds by Jymmiee
To cut Foam and possible molds
