I have build this tiny but powerfull CNC machine mainly using the universal gantry plates for the X and Y axis. Also another innovative part is the fact that I assembled the Z gantry with 2 aluminum sections of 20X40 and one aluminum seccion of the 20X20.
Mighty Chihuahua
Build in 'X/Y Table Style CNC Mill' published by Jose Alezandre, Oct 26, 2020.
The idea was to use materials from previuos failed projects into a succesful one. I have build this tiny but powerfull CNC machine mainly using the universal gantry plates for the X and Y axis. Also another innovative part is the fact that I assembled the Z gantry with 2 aluminum sections of 20X40 and one aluminum seccion of the 20X20. I used NEMA 17 stepper motors with GT2 pulleys. This was designed on Fusion360
Build Author Jose Alezandre, Find all builds by Jose Alezandre
I wanted to use material from previous projects into a succesful project. -
Qty Part Name Part Link Comments 4 V-Slot® Gantry Plate - Universal https://openbuildspartstore.com/v-slot-gantry-plate-unive... Link 1 V-Slot® 20x40 Linear Rail https://openbuildspartstore.com/v-slot-20x40-linear-rail/ Link This one is 1000 in length 3 Motor Mount Plate - NEMA 17 Stepper Motor https://openbuildspartstore.com/motor-mount-plate-nema-17... Link 2 Threaded Rod Plate - NEMA 23 Stepper Motor https://openbuildspartstore.com/threaded-rod-plate-nema-2... Link 2 V-Slot® 20x40 Linear Rail https://openbuildspartstore.com/v-slot-20x40-linear-rail/ Link These one are 500 mm in length each -
