As the world scrambles to find solutions to shortages in medical equipment, the MIT team came out with a ventilator prototype which has sparked many makers everywhere to find low cost replacement that could possibly be used to save lives.
This is a converted version of that prototype using stock OpenBuilds parts plus a couple of 1/4" acrylic sheet.
I used 1/8" acrylic in this one as it was what i had on hand.
The gear was 3D printed but a laser would also would have need as great choice.
Ive tested the NEMA17 with a basic gcode and got everything moving but a NEMA23 would be a better choice i think. File attached has both options.
This is a work in progress but hope the community can chime in and make it better.
MIT E-Vent | MIT Emergency Ventilator
Build in 'Everything Else' published by Ariel Yahni, Apr 18, 2020.
Ventilator prototype based of OpenBuilds Stock parts
John Davies and Mark Carew like this. -
Build Author Ariel Yahni, Find all builds by Ariel Yahni
Qty Part Name Part Link Comments 2 V-Slot Linear Rail 20x80 https://openbuildspartstore.com/v-slot-20x80-linear-rail/... Link 2 V-Slot Linear Rail 20x40 https://openbuildspartstore.com/v-slot-20x40-linear-rail/... Link 12 Black Angle Corner Connector https://openbuildspartstore.com/black-angle-corner-connec... Link 2 Low Profile Screws M5 (10 Pack) https://openbuildspartstore.com/low-profile-screws-m5-10-... Link 4 Cast Acrylic - Clear https://openbuildspartstore.com/cast-acrylic-clear/?ref=r... Link 1 Up-Cut Single Flute Solid Carbide End Mill 1/8" https://openbuildspartstore.com/up-cut-single-flute-solid... Link 1 Quad Tee Nut - MAKERLINK (10 Pack) https://openbuildspartstore.com/quad-tee-nut-makerlink-10... Link 2 Tee Nuts - M5 (10 Pack) https://openbuildspartstore.com/tee-nuts-m5-10-pack/?ref=... Link -
