      I've designed a 250mm size delta using primarily stock hardware and few 3d printed parts. While I got interested in 3d printing because of the reprap project, I think there can be simpler ways to build that a large selection of printed parts. This design uses mostly off the shelf hardware and laser cut parts. The current design still has a couple printed parts were it makes sense.
      The connector plates, carriages and end effector plate are laser cut. For the first prototype, I used plywood, but expect to change to acrylic once the bugs are worked out.
      Update:
      I got great results with this build and have rebuilt with acrylic. The BOM is uploaded and I will have the laser cut parts available if you want to build your own.
      Doc Ross and Polymorph like this.
    This design was developed to minimize 3d printed parts and use as many stock components as possible.
