First initiation of design, things have changed, see discussion and further down.
Parts List is now based on this community improved design (Base design with all OpenBuilts Parts without custom built parts you can make yourself once built and up and running)
Moag's CNC Mill
Build in 'CNC ROUTER BUILDS' published by Moag, May 16, 2016.
A design in progress, to 3D carve two-part Aluminium injection moulds for Soft Plastic Lures and Lead Jigs, so I can prototype some of the concepts rattling around in my head. All Openbuilds parts where possible, 1000x500mm footprint, 0.8kw Water-cooled Spindle?, High Torque Stepper?,Smoothieboard?, I still have no idea. As a newbie to the CNC world, any wisdom would be welcome to take this from just a idea into reality so I can start playing with all this awesome stuff. Thanks in advance
mlundsveen, vovan15, MStillman1966 and 21 others like this. -
Build Author Moag, Find all builds by Moag
Oh no, another "Hobby"
Guess I just like designing and making stuff!
To many to list, your all awesome, I think I've gone through the whole site. Thanks all. -
Qty Part Name Part Link Comments 1 C-Beam™ Linear Rail (1000 mm) http://openbuildspartstore.com/c-beam-linear-rail/ Link X Beam 4 C-Beam™ Linear Rail (500 mm) http://openbuildspartstore.com/c-beam-linear-rail/ Link 2x Frame Sides, 2x Y Beam 1 C-Beam™ Linear Rail (250 mm) http://openbuildspartstore.com/c-beam-linear-rail/ Link Z Beam 2 V-Slot™ Linear Rail 20 x 80 mm (1000 mm) http://openbuildspartstore.com/v-slot-linear-rail/ Link Frame Front and Back 1 V-Slot™ Linear Rail 40 x 40 mm (1000 mm) http://openbuildspartstore.com/v-slot-linear-rail/ Link * Optional. Cut down to 960mm Back of X Beam for Cable Chain Support and two extra wheels. 7 C-Beam™ Gantry Plate - XLarge http://openbuildspartstore.com/c-beam-gantry-plate-xlarge/ Link XZ axis and 2x Y axis 8 C-Beam™ End Mount http://openbuildspartstore.com/c-beam-end-mount/ Link For XYZ activators 14 90 Degree Joining Plate http://openbuildspartstore.com/90-degree-joining-plate/ Link Two for each bottom corner of Frame, 6 for x supports 40 Black Angle Corner Connector http://openbuildspartstore.com/black-angle-corner-connector/ Link Every where LOL 8 Aluminium Spacers (40 mm) http://openbuildspartstore.com/aluminum-spacers/ Link Stand offs for Steppers (* double up if planing on making your our own custom activator end plates) 18 Aluminium Spacers (9 mm) http://openbuildspartstore.com/aluminum-spacers/ Link Spacers between Double Wheel Assemblies 21 Aluminium Spacers (6 mm) http://openbuildspartstore.com/aluminum-spacers/ Link Wheel Assemblies 16 Aluminium Spacers (3 mm) http://openbuildspartstore.com/aluminum-spacers/ Link Stand off for Acme Nut Blocks 21 Eccentric Spacer (6 mm) http://openbuildspartstore.com/eccentric-spacer/ Link Wheel Assembly 42 Xtreme Solid V Wheel™ Kit http://openbuildspartstore.com/xtreme-solid-v-wheel-kit/ Link 8 Nut Block for 8mm Metric Acme Lead Screw http://openbuildspartstore.com/nut-block-for-8mm-metric-a... Link 1 8mm Metric Acme Lead Screw (250 mm) http://openbuildspartstore.com/8mm-metric-acme-lead-screw/ Link Z axis 2 8mm Metric Acme Lead Screw (500 mm) http://openbuildspartstore.com/8mm-metric-acme-lead-screw/ Link Double Y axis 1 8mm Metric Acme Lead Screw (1000 mm) http://openbuildspartstore.com/8mm-metric-acme-lead-screw/ Link X axis 8 Ball Bearing 688Z 8x16x5 http://openbuildspartstore.com/ball-bearing-688z-8x16x5/ Link 8 Lock Collar (8 mm) http://openbuildspartstore.com/lock-collar/ Link 4 1/4" x 8mm Flexible Coupling http://openbuildspartstore.com/1-4-x-8mm-flexible-coupling/ Link 130 Tee Nuts (25 Pack) http://openbuildspartstore.com/tee-nuts-25-pack/ Link 6 packs of 25 80 Low Profile Screws M5 (8 mm) http://openbuildspartstore.com/low-profile-screws-m5/ Link Four packs of 25 50 Low Profile Screws M5 (10 mm) http://openbuildspartstore.com/low-profile-screws-m5/ Link Three packs of 25 (You could get away with two packs, just don't loss any! spares are good) 24 Low Profile Screws M5 (15 mm) http://openbuildspartstore.com/low-profile-screws-m5/ Link One pack of 25 (One spare) 16 Low Profile Screws M5 (20 mm) http://openbuildspartstore.com/low-profile-screws-m5/ Link One pack of 25 6 Low Profile Screws M5 (30 mm) http://openbuildspartstore.com/low-profile-screws-m5/ Link One pack of 25 16 Low Profile Screws M5 (55 mm) http://openbuildspartstore.com/low-profile-screws-m5/ Link One pack of 25 18 Low Profile Screws M5 (60 mm) http://openbuildspartstore.com/low-profile-screws-m5/ Link One Pack of 25 8 8mm Shim http://openbuildspartstore.com/8mm-shim/ Link 16 Precision Shim - 10x5x1mm http://openbuildspartstore.com/precision-shim-10x5x1mm/ Link Stand off for Acme Nut Blocks 1 Holman 65 mm x 1 m PVC DWV Pipe http://www.bunnings.com.au/holman-65mm-x-1m-pvc-dwv-pipe_... Link Use to pack out Spindle Mount (Outside dia' 70 mm, inside 65 mm) 2 Router/Spindle Mount http://openbuildspartstore.com/router-spindle-mount/ Link *Option of losing one, it all depends on what your mounting. 3 TIC 22mm White Rubber Screw on Bumper - 4 Pack http://www.bunnings.com.au/tic-22mm-white-rubber-screw-on... Link "Practise Wheels"
Bump Stops
8 Micro Limit Switch http://openbuildspartstore.com/micro-limit-switch/ Link 1 8.0 KW ER11 Water Cooled Spindle & VDF Link About 3 kg, so are still considering a 2.8 kg Air cooled 1 24V/14.6A Power Supply http://openbuildspartstore.com/24v-14-6a-power-supply/ Link *Dependant on what you are planing to run 1 CNC xPRO V2 Controller Stepper Driver http://openbuildspartstore.com/cnc-xpro-v2-controller-ste... Link * Dependant on what you intend to run ??? SmoothieBoard? 3 NEMA 23 Stepper Motor http://openbuildspartstore.com/nema-23-stepper-motor/ Link Love to give the "High Torque" ones a go, but the CNC xPRO might have second thoughts and the X axis Beam might sag under the weight. 0 Wire Link How long is a piece of string? 0 Base Plate?? Aluminium? Perspex? MDF; don't know. Link All the above is worked out on paper and isn't a real world thing yet. Wish me luck with my first foray into the" roll your own" World of CNC Router Builds. 0 Link 0 Link 0 Link
