Hy guys !
I want to build a multimaterial 3D printer that could print plaster, clay, concrete, …etc. The printing head will be changed depending on material I want to use.
It's a cartesian style 3D printer. Nothing special, except its size (150x150x150 cm), and the motors : indeed, I need powerful motors because the heads may be heavy (specially when I will use concrete).
I already built a 3D printer 50x50x50 cm based on the Maximus. It works well now (thanks to several OpenBuilders who helped me to make it successfully !)
WHY ?
I want to produce sculptures using 3D printing (I'am architect and artist as well).
ELECTRONICS
- ARDUINO Mega 2560 + RAMPS 1.4 + power supply 12V
- Leadshine DM 5042 external driver + Power supply 36V + NEMA 23 stepper motor
SOFTWARE
- Repetier Host to communicate with the Ramps
- ARDUINO to upload the firmware (Marlin)
MECANIC
- V-Slots rails 40x40 + home-made plates
- everything goes fine on the side of the build
MULIMATERIAL 3D PRINTER (in progress)
Build in 'Cartesian Style Bots' published by Keteland, May 16, 2016.
ELECTRONICS - ARDUINO Mega 2560 + RAMPS 1.4 + power supply 12V - Leadshine DM 5042 external driver + Power supply 36V + NEMA 23 stepper motor SOFTWARE - Repetier Host to communicate with the Ramps - ARDUINO to upload the firmware (Marlin) MECANIC - V-Slots rails 40x40 + home-made plates - everything goes fine on the side of the build
TROUBLE
I have a little trouble with the electronics and the Leadshine drivers ; the motor NEMA 23 reacts when the ARDUINO board receives a command … but not as expected : indeed, it makes a little noise like a "zzzzzzzzzzzzzzzzzzz" instead of moving normally.
I checked several times the connections and all the system. It seems to be fine.
I do not understand where the trouble comes from. Anyone could help me ?
Martan Rauber de Souza, Dmitry Litvinov, Robert E. Nee and 1 other person like this. -
Build Author Keteland, Find all builds by Keteland
I'm a artist and sculptor : I want to create sculptures using 3D printing (multimaterial such as plaster, clay, concrete …) -
