NEMA 17 Belt and Pinion Actuator
Hi everyone, this is a really simple and cool build displaying how the belt and pinion system operates and how it can be utilized in your builds. This system is accurate and efficient and offers a quick and easy solution for builds that you want to incorporate a belt drive system. This is just the beginning of how this system can work for you and we can't wait to see how this inspires new ideas in the community!
- It utilizes the Solid Delrin V Wheels.
- Strong mounting configuration using Universal Gantry Plate.
- GT2 Timing Belt used with GT2 20 Tooth Timing Pulley.
- Available in different sizes and colors.
- Travel for the 500mm version is 410mm
- Travel for the 1000mm version is 820mm
- Travel for the 1500mm version is 1230mm
- Pulley Tooth Count: 20 teeth.
- GT2 Belt Tooth Pitch: 2mm per tooth.
- Steps Per Revolution for the Stepper Motor: 200 steps (1.8° per step).
- Microstepping Setting: 1/8th microstepping
- Steps per mm are: 40 steps/mm
If your interested in purchasing Belt and Pinion Actuators and Parts please click here.
BUILD VIDEO: NEMA 17 BELT AND PINION.
Grab your Bundle Pack Here Today and Start Your Build!
Build in 'ACTUATOR' published by Mark Carew, Aug 20, 2024.
This Belt and Pinion actuator is a great example of how easy it is to convert your machine into a belt drive system.
RamonMedina and GrayUK like this. -
OpenBuilds is always innovating and creating solutions through our modular building system. -
