This build is currently "Work in Progress".
Chicken scratch design sketches are drawn and CAD modeling is in progress.
Components are purchased as a specific CAD model is completed.
Design requirements are set and stated below.
The unit shall be/have:
Fairly Quiet
Fast
Enclosed
24 Volt power supply driven.
Three axis motion to be lead screw driven.
300 x 300 x 200+ Build Area
Brackets are 3D Printed
Made of 20x20(40) Aluminum V-Rail Extrusion
Electronics are fully enclosed.
Screen and SD card slot to be accessible @ front panel.
Initially run on latest Marlin firmware build... Update to 32Bit Smoothieware + board once functioning.
The unit shall use Genuine Quality Components:
Igus Bearings
E3D V6 Direct Extruder
E3D Titan Extruder Drive
BL Touch Sensor
Flat Aluminum Bed w/Glass Top + PEI Sheet
Silicone Bed Heat Pad
Norm Inverted - Cartesian
Build in 'Cartesian Style Bots' published by Joortiz1, Aug 2, 2017.
As a tinkerer and hobbyist I need a reliable quality printer on a budget... Meaning I'm not looking to buy a: Prusa, Zortrax or LulzBot because of the added cost their marketing adds. I can definitely build a machine of hopefully equal quality at a lower cost that is not impacted by the marked-up priced from a large reputable manufacturer. I will need to dedicate time and more time for design shakedowns to ensure I produce a quality machine. Bare with me on this build... Thanks!
Todd A Whetstone and ihopeifshv like this. -
Build Author Joortiz1, Find all builds by Joortiz1
- CC - Attribution No Derivs - CC BY ND
