So I decided to build a CNC router to aid my making career.
I make interactive installations and work with LED's plus run my own travelling show www.digitalfunfair.co.uk
I wanted to get into the technology and my son showed some interest too which was a bonus.
After a medium amount of research I ordered a kit from Ooznest because it looked like a good bet for a first timer. At least if you are based in UK
There was a typical mix up with the courier company, UPS, which seems to be almost standard for our address, so I didn't get to start building it until after Easter.
The instructions made everything pretty clear and I build the kit up in three sessions - about 10 hours probably - plus add a bit on for me lying because I want to appear more competent than I really am.
In fact part of the reason I was keen on the technology was because of my terrible finishing skills. I was good at Maths at school but give me a ruler and ask me to measure a line and I could never get the same answer twice. At the same time these (lack of) skills means it might be a bit of an ask to build the machine to a decent level!
Largely the build went ok. It was a bit of a struggle getting the Z axis set up and I hope I got it right. At first the bearing kept popping out as I moved the carriage but then I followed the video and think I got it right. Not sure what I was doing wrong.
The main difficulty I had was knowing how tight to do the eccentric spacers. I did them as loose as I could without their being any movement. When I'd put the kit together my son pointed out a couple of the top wheels were loose so I tightened up the relevant spacers. Time will tell I guess.
Anyway I've really enjoyed it so far. I'm off to Portugal for a week on Tuesday so hoping I can get some kind of action before then - but its looking doubtful!
Ooznest build - 1500mm x 1000mm
Build in 'Cartesian Style CNC' published by gavspav, Apr 2, 2016.
Its the first build for me so its just the story of me attempting to build the kit and hopefully end up with something I can use. Hopefully without destroying anything or anyone.
Build Author gavspav, Find all builds by gavspav
I run a travelling show, the Digital Funfair, and would like to cut wood and acrylic to help me build stuff for the show. Also just interested in learning more about the technology.
