Much more detail to come, but here is the preview of the OX PPR - Portable Plasma Router. The main design criteria for this unit are:
1) Mainly a plasma cutter, but also a router. Just need to change the tool holder.
2) Leadscrews instead of belts. (Currently built with belts. Could be changed to screws later)
3) X axis ~60mm lower to accommodate a lower tool position.
4) Wheels on Y axis face outward, to reduce the amount of debris on wheels.
--------- BUILD PROGRESS IS IN THE DISCUSSION, THIS PAGE WILL JUT ---------
--------- LIST THE MAJOR COMPONENTS AND CURRENT PHOTOS -------------------
Gantry: Custom OX Variation with Stepper mounts and X-axis mounts swapped
Dimensions: Current working dimensions, about 21" x 40" x 5"
Controller: Planet-CNC USB Mark 3/4
Drive Chain: X/Y Belt, to be upgraded to double belt. Z is 8mm lead screw
Power: 24V, 350W
Drivers: TB6600 4.5A
Plasma: Lotos LTP6000D w/ CC02 Torch
THC: CANDCNC LCTHC
Cart: Custom Welded Downdraft w/ 3/4 HP Exhaust
Information below is obsolete. No longer using lead screws, using belts for now. The gantry plate design still supports lead screw placement, if the machine was to be converted in the future.
The 3D model is a work in progress. However, it's starting to look good. Details on the build to come.![]()
OX PPR - Portable Plasma/Router
Build in 'Cartesian Style CNC' published by Steve B, Dec 18, 2015.
PPR = Portable Plasma/Router. A ~30x30"work area with leadscrews. Work surface is below support members. Can be placed ONTO cutting surface.
You, Robert R. Norman, Phil_Can and 8 others like this. -
Build Author Steve B, Find all builds by Steve B
