I live in a retirement village where space is at a premium. I love my OX but would like to try some 4th axis carving as well. I don't have room for another machine, so I plan to mount the head & tailstock to a base board under the current frame. I'll get 300mm of cut length.I think I'll put a half width board along side so I can still do small jobs. When I need to do larger stuff, it's just a matter of undoing the clamps & lift the OX off, replace the woodwork & away we go. In retrospect I could have purchased a smaller set, but on paper 100 mm didn't seem too big. I've seen some You Tube movies of small figurines being carved & I'd like to emulate them. I've read a little & gone through the Vectric tutorial, but still have an awful lot to learn. Any advice and / or pointers gratefully accepted
The project will be a little way off because of this.
THIS BUILD WAS ABANDONED.
I decided that I would end up with a machine doing a poor job in 2 areas, so I went for a look around & saw the C-Beam which convinced me to make a second machine.
OX TWO in ONE
Build in 'Other Lathe Build' published by gwandad, Dec 3, 2015.
What I'm doing is pretty self explanatory. I've put a few pictures up
Woodify, bnbellis3377, Mark Carew and 2 others like this. -
Build Author gwandad, Find all builds by gwandad
