      1 votes
      BCN3D Sigmax + Voron = Sigron
      Hey Everyone, this is my new IDEX 3D printer design. This is the start of my dream build that is an IDEX with a moving gantry. It has a 400 x 400 x 400ish build volume. The final build will be fully enclosed.
      My goal with this printer is to build a printer that can print every filament type (excluding PEI, etc.) with ease.
      I started with the BCN3D Sigmax R19 step file and modified the design to use aluminum extrusions and printed parts instead of aluminum sheet. I added 2 Voron Afterburner direct drive extruders and modified them to run on a single linear rail. I might try to use double linear rail for the x axis in the future.
      Main Features:
      1. IDEX
      2. Moving gantry
      3. All linear rails
      4. Large build volume
      5. Direct drive
      This is a work in progress, and I will continue to update it in the coming months. Any feedback is welcome.
      Thanks for your interest :)
      8/29: Added front belt mounts
      8/29: Added bottom belts to design
      Suki, Birger, Barey and 14 others like this.
    I want to build a high quality engineering grade printer at a lower cost.
