As far as builds go this is pretty simple. I have a steel plate with .008 inch slots in it that are quite worn. I had the idea of filling the slots with JB Weld and then recut them. All I needed was a small saw and a way to keep the blade perpendicular to the plate and cut in a straight line. The OpenBuilds Acro 55 looked like it would work for me. I did not need anything other than the base package. I bought a saw from Harbor Freight and just mounted it. I used aluminum blocks and c-clamps to keep the gantry in the X position I needed it and manually moved it in the Y direction to cut. I've attached two videos of the device in action.
Small Slot Cutter
Build in 'Everything Else' published by Kedals, Nov 29, 2018.
A build to cut .008 inch slots into JB Weld.
Mark Carew and GrayUK like this. -
Build Author Kedals, Find all builds by Kedals
I have a steel plate with thin (.008 inch) slots in it that are worn out. I'm having difficulties finding someone that can make me a new plate. I decided to try making my own tool to cut these slots. -
Qty Part Name Part Link Comments 1 1 Ă— OpenBuilds ACRO 55 20" x 20" https://openbuildspartstore.com/openbuilds-acro-55-20-x-20/ Link Nice kit. Simple to assemble 1 2 in. Mini Bench Top Cut-Off Saw https://www.harborfreight.com/2-in-mini-bench-top-cut-off... Link Picked this up at my local Harbor freight. I removed the base and made some mods to the case. 1 Jeweler's Slotting Saws https://exacttooling.com/pages/cuttingtools-solidround-ke... Link 2 C clamp https://www.harborfreight.com/4-in-industrial-c-clamp-621... Link 4 Aluminum Flat Bar https://www.ebay.com/itm/4-Pieces-1-2-X-1-1-2-ALUMINUM-60... Link -
