You'll need:
3 x 20x20mm V-Slot® Linear Rail
3 x Black Angle Corner Connector
6 x Tee Nuts (25 Pack)
6 x 6mm Low Profile Screws M5
Cut your V-Slot ends to 45 deg, then turn to an adjacent side, and make another 45 degree cut, ensuring the same distance from the end (a stop-block on the other end of the rail helps a lot!). The more precise you can line up the two cuts, the better the resulting mitered corner will look once complete
Join two of the rails with a 90 deg Corner Connector as shown
Add two more 90 deg Corner Connectors on the open side of the miter
Insert screws + t-nuts and then Insert the upright into the corner
Tighten and adjust the miter until all the edges line up as good as they can
If you end up using this method to make a mitered corner in one of your builds, let me know in the Discussion tab! Would love to see it!
The Almost Perfect 3 Way Mitre (with Angle Corner Connectors)
Build in 'Everything Else' published by Peter Van Der Walt, Apr 6, 2017.
A quick and easy way to make a 3-way mitered corner using Corner Connectors
Jason Harris, gwandad, Mark Carew and 1 other person like this. -
Build Author Peter Van Der Walt, Find all builds by Peter Van Der Walt
Qty Part Name Part Link Comments 3 20x20mm V-Slot® Linear Rail http://openbuildspartstore.com/v-slot-linear-rail/ Link 3 Black Angle Corner Connector http://openbuildspartstore.com/black-angle-corner-connector/ Link 6 Tee Nuts http://openbuildspartstore.com/tee-nuts-25-pack/ Link 6 6mm Low Profile Screws M5 http://openbuildspartstore.com/low-profile-screws-m5/ Link
