This is a work in progress, nearing completion
I have attached my BOM to the files section, I will add the .stl's when I have a chance. It has been quite a learning experience sourcing and determining what parts I wanted to use. I knew that I wanted to base this on a mighyboard, mostly to make it compatible with my current clone. Blue parts are PETG from esun. Black parts are ABS. Printed 40% rectangle infill with 4 shells. 4 top and bottom floors.
To-Do List
- model strain relief for X axis endstop
Long term To-Do
Correct BOM
- model/produce dashboard - two small enclosures vrail mounted, one for LED controller
- model/produce vrail wiring inlet - tunnel entrance to the vrail slot covers, hiding wiring in the grooves
- rotate motherboard - floor is acrylic, there's some blinky lights that could be seen if it were face up
- model/produce umbilical strain relief - I believe I will add to the Y endstop an anchor for the umbilical, same for backside of XY gantry plate.
Produce Assembly instruction
Triple C-Bot
Build in '3D PRINTER BUILDS' published by adamcooks, Aug 14, 2015.
Based on the work of Carl Feniak and his C-Bot. A robust Core XY style 3D printer that has a clean parallel belt implementation and whose dimensions are adaptable to meet builder's needs. The use of open builds V-slot and other open hardware make customization easy. Utilizing a 300x300 build plate this derivation utilizes three lead screws, synced to a single motor via gt2 belt
Based on the work of Carl Feniak, Dan Newman, Ryan Carlyle Jetguy and the rest of the open source community
zizivivi, xiaoqianzi15, Kollins Bull and 13 others like this. -
Build Author adamcooks, Find all builds by adamcooks
I wanted to build an enclosable core xy printer, based on the Mightyboard and the Sailfish firmware -
