and Simple X/Y Table System Example
Screw-driven linear motion systems are desired for high thrust, stiffness and tight precision in high-load, moderate-speed applications.
-Build a simple linear actuator using the high quality OpenBuilds Parts -
-Build two of these actuators and connect them together for a great X/Y linear stage -
Check out the video at this point to connect the two stages together
Build the NEMA 23 X/Y Table
Mounting hardware needed to create the XY table
(4) Nylon Insert Nuts (4) Slot Washer
-Detailed model files are included to help bring your build to life! -
Be sure to download the included model (Files Tab) to study these examples in more detail and see how they can be applied to your builds.
Related helpful build: X-Y Stage Hidden Acme Rod Example
Please Note: That there are many ways and variations to building screw driven actuators. These are just a few examples of the ways in which we are sharing our builds so that others can learn and build from.
Building is half the fun!
Enjoy
Build in 'ACTUATOR' published by Mark Carew, Mar 11, 2025.
Mr. Scanlon, Abdulqadir B Jetpurwala, okjoey and 6 others like this. -
To share a simple example on how to build an inexpensive Neam 23 actuator with all stock parts. This same actuator example can also be made into a simple X/Y stage -
