This build is a continuation of my Posi-Drive Leveling series of printers. It uses one Z axis motor syncing two Z axis screws with a timing belt to produce a permanently level printer.
The Z axis runs on Openbuilds Mini V-wheels. The Vulcan Bot has a print area of 8" x 12" x 8". Total cost (depending on source) $400.
PSU and KFB3.0 controller board box are attached to an 1270mm x 335mm x 3/16" sheet of ABS attached to the bottom of the frame, consolidating the printer into a single unit that can be easily moved from location to location.
Assembled SKP file http://3dwrx.com/VulcanBot/skp.zip
STL files http://3dwrx.com/VulcanBot/stl.zip
There is an 108 step tutorial for building the Vulcan Bot at:
Build VulcanBot
Vulcan Bot
Build in 'Cartesian Style Bots' published by Keith Davis, Aug 25, 2019.
A 200mm x 300mm x 200mm workhorse that never needs leveling due to Posi-Drive Leveling design.
Mark Carew likes this. -
Build Author Keith Davis, Find all builds by Keith Davis
- CC - Attribution No Derivs - CC BY ND
It is my workshop's workhorse
