Y-1200 Build
The Y-1200 has a cutting area of 1200 x 600mm and the main chassis has a external size of 1620 x 955 x 450mm.
The recommended power output is 60-90W, this can also be increased with the use of an extension box.
Y-1200 co2 laser
Build in 'Laser Cutter Builds' published by Gareth90, May 31, 2022.
Y-1200 Build The Y-1200 has a cutting area of 1200 x 600mm and the main chassis has a external size of 1620 x 955 x 450mm. The recommended power output is 60-90W, this can also be increased with the use of an extension box. designed by furtherfabrication ROB CHESNEY FREELANCE INDUSTRIAL DESIGNER.
Lars Kapstad, MeaningLess, Osirion Mechatronics and 2 others like this. -
Build Author Gareth90, Find all builds by Gareth90
ROB CHESNEY on youtubeInspired by
ROB CHESNEY -
Qty Part Name Part Link Comments 1 80W PSU CO2 Laser Power Supply https://www.cloudraylaser.com/products/cloudray-80w-110-2... Link 1 Cloudray 50W CO2 Laser Tube https://www.ebay.co.uk/itm/402312718571 Link 1 Openbuilds BlackBox Controller https://ooznest.co.uk/product/openbuilds-blackbox-control... Link 1 12/24V 250W Power Supply https://ooznest.co.uk/product/250w-power-supply-fan/ Link 1 CW-3000 Water Cooler (S&A) https://www.google.com/search?q=CW-3000+Water+Cooler+(S%2... Link 1 Laser Head and Mirror Set (Cloudray) https://www.cloudraylaser.com/products/cloudray-c-series-... Link 1 AC60 HAILEA AIR PUMP 60L/min https://www.ebay.co.uk/itm/261994536504 Link 1 Y-1200 Build Guide https://www.furtherfabrication.com/resources/y1200-build-... Link 1 Y-1200 Parts List https://www.furtherfabrication.com/resources/y1200-partsl... Link 1 Y-1200 CAD MODEL https://www.furtherfabrication.com/resources/y1200-cadmodel Link -
