Print using ABS (medium accuracy, minimal supports needed), insert into V-slot, twist 90 degrees, use as a hole to screw on things. The screw expands the inserted part, making it sturdier.
Simple 3D-printed V-slot insert for screw-on accessories 2017-05-25
Insert for the V-slot that accepts a 4 mm plastic/wood screw
Tags:
