- Aspire, and OpenBuilds Control Software
- Machine Time:
- 45 minutes
- .25" End Mill, .50" 90 Degree VBit
- Feeds & Speeds:
- Details provided in the project
- Red Oak
This is the most practical project I have created so far and I have to say I use these coasters everyday!
I started off with a surfacing toolpath to ensure that my material was completely flat and I wanted my coasters to be .50" Thick. The humidity has been pretty bad as of late, so I did encounter some warp in the red oak I was using. The surfacing toolpath worked like a charm to make my material level again.
This is the finished surfacing toolpath.
Next I started my V-carving toolpath. I used a .50" 90 Degree V-Bit for this part of the project.
I absolutely love the BlackBox with the Ghost Case!
After finishing the V-carve toolpath, it was time to cut these beauties out!
I used a .25" End Mill for the profile cut because I couldn't find my .125" End Mill, so I did encounter some overlapping cuts because of the bit diameter, but the coasters still turned out great.
To Finish the project I sanded down the coasters and added a polyshade stain.
Hope you guys enjoyed the project! I've uploaded the files below so you can customize your own coasters.
MaryD, Mark Carew, rokasni and 1 other person like this.
