This project is a fairly simple three part slot together hanging planter. Perfect for plant lovers and a perfect way to decorate a dull wall or corner with greenery!
- Machine Type:
- Other Machine
- Vectric Aspire, VCarve Pro, VCarve Desktop, Cut2D Pro, Cut2D Desktop
- Electronics:
- Other Controller
- Machine Time:
- <30 mins
- Various see PDF
- Plywood in Project example
Included in the file are two layers called “Original Vectors for Alteration”. These vectors outline all the dimensions you would need to change to accommodate the material thickness you plan to use. Remember, as this is a slot together project it is wise to run test cuts to check the allowances in the toolpaths for the best assembled slot fit.
Don't have Vectric software? Don't worry, these files are available to cut on your CNC machine with our free trial software. Simply head over to Free Trial Comparision | Vectric to download a free trial and the free files.
