The Standing Trees file consists of three trees that slot into the base. Simple and effective! As this is a slot together project you will need to alter the slot sizes & fillet radiuses according to the material thickness you plan to use. It’s good practice to always create test slots first before cutting the whole part out so that you can weigh up which overcut provides the best fit (Refer to the Video for more information on this).
- Vectric
- Machine Time:
- < 30 mins
- 0.25" End Mill
- Feeds & Speeds:
- Various
- Ply Wood
I created a video for the Project here:
I have attached a zip file which includes two sets of files to make this super easy to machine. The first set
contains the vectors and toolpath information ready for you to output the toolpaths, for this option, you will need
to either own Vectric software or download the FREE trial software, where you will be able to output the gcode
for this project. You can download the Trial software here.The second set includes the vectors for you to use in your own CAD/CAM software package.
Happy Making
