- Inkscape/Vcarve Pro/Mach 3
- Machine Time:
- 30 minutes
- 0.125" end mill
- Feeds & Speeds:
- 11000 RPM; 20 IPM
- 3/4" Baltic Birch plywood
Design is in Inkscape:
Export the file as DXF and import into Vcarve Pro
Select everything and close loops
Select the inner paths and create a profile cut
Repeat for the outside (create tabs if you think you need to)
Check the preview
Save the G-code (port processor depends on your CNC machine)
Transfer to your CNC and enjoy your unique hearts
Note: .svg file attached as a .zip
