1515 build video discrepancy for X-axis Carriage
Discussion in 'CNC Mills/Routers' started by Valin6210, Mar 28, 2024.
  1. Valin6210
    Valin6210 New
    I'm assembling my LEAD 1515 and ran into a discrepancy in the build video. When assembling the two plate/wheel assemblies for the X-axis Carriage Assembly the video is very specific about putting the transmission components on the side where the nuts go on the 65mm screws. However, in the step of mounting the two assemblies to the V-slot it shows the transmission blocks on the other side, where the screw heads are.
    Which is correct?
    Edit: so after watching the rest of that step the end assembly shows the transmission blocks on the side with the nuts. Looks like the video was shot with an incorrectly assembled piece and then corrected at the end but not at the beginning.
    #1 Valin6210, Mar 28, 2024
    Checkout the 3D model on the LEAD 1515's build page > files and drawings tab. In 3D you can zoom and investigate up close any sections you are unsure of. Its meant to have it open alongside the video
    OpenBuilds LEAD CNC Machine 1515 (60" x 60")
