2-1/2 D milling
Discussion in 'CNC Mills/Routers' started by Bferster, Dec 15, 2022.
  1. Bferster
    Bferster Well-Known
    I need to cut a round edge on some wood that curves.
    How can I generate gcode to do this?
    I can model it in TinkerCad, which output as .obj or .stl files
    I usually use the free version of Easel to generate gcode, but can download something else.
  2. Gary Caruso
    You can 3d carve an stl file. I use Estlcam but I'm sure other ways are available.
  3. Giarc
    it would also be easy to model in fusion 360 which will generate gcode to cut it as well, but Estlcam has a quicker learning curve IMO. Vectric Vcarve is by far the easiest, but it costs money.
  4. Bferster
    Bferster Well-Known
    I’ll check out Esticam, Thanks!
  5. Bferster
    Bferster Well-Known
    I have Vectric cut 2D, which I like but am reluctant to upgrade to vCarve fo something I’ll rarely do
    Giarc likes this.
  6. Bferster
    Bferster Well-Known
    You were right. Estlcam rocks!
    Gary Caruso likes this.
