3018 Grbl arduino problem
Discussion in 'Control Software' started by michael ipsen, Jun 13, 2022.
  1. michael ipsen
    hello
    I'm in huge trouble.
    I don't know what I've got done but my machine is conected to the control but I can't move the spindle any way or the work surface. what have I done wrong? I just ran another task without any problems
  2. Alex Chambers
    We need a bit more info - what is your full electronics setup? I know you have an Arduino, but what stepper drivers? What power supply? Have you checked the output voltage of the power supply? and the wiring and connections?
    Do your stepper motors power up? - they would be extremely difficult to turn if powered and should get a bit warm (but not too hot to touch). Don't turn the stepper motors by hand while powered on or if they are connected to your controller - just enough to feel if they resist turning by hand.
    Could be lots of things, but the above is a starting point (I'd check wiring - power OFF - for loose connections first).
    Rick 2.0 likes this.
  3. michael ipsen
    hello Alex.
    my setup is this.
    motherbord arduino fake with power supply 12/24v
    stepper motor nema17
    500w seperrat spindle power suply
