About the OpenBuilds Lead Screw Customization.
Discussion in 'General Talk' started by ReneX, Nov 28, 2023.
  1. ReneX
    ReneX New
    Hello,
    Looking at the part store 8mm Metric Acme Lead Screw page, I see the following note: These lead screws have been customized to work directly with OpenBuilds system. Could someone help me understands the following:
    1. What exactly does this lead screw customization consists of?
    2. Why was this customization needed? Why couldn't OpenBuilds just use a standard lead screw?
    Thanks you.
  2. Alex Chambers
    There is a very small reduction in diameter to make it easier to insert into the nut blocks. It tells you in the link you posted - the diameter is 7.8 mm.
  3. ReneX
    ReneX New
    Thank you,
    There has got to be more to this than just that, I mean... wouldn't it have been a lot easier to just make the nut block lead screw diameter a little bigger? The specs for the nut block could be to have a lead screw whole diameter of say 8.2 mm so that the lead screw could be inserted just as easily. Given that the nut block is already a custom made (I think) OpenBuilds nut block, this would not incur any extra cost.
    Not only would making the nut block lead screw diametric a little bigger be essentially free, I can only guess that having a standardize lead screw diameter would be better when doing extra customization to our builds such as wanting to swap existing OpenBuilds nut blocks with other ones such as the ones that have ball bearings etc.
    I think I am missing something here....
    Thanks.
  4. Giarc
    The ones that have ball bearings are "ball screws" and no company's Delrin (or the knock-offs made of inferior plastics) nut blocks will work on a ball screw, nor will the ball nuts, manufactured by any company work on a lead screw. You could probably very easily modify your machine to use ball screws and ball nuts if you wanted that option.
  5. Rick 2.0
    To specifically answer your question, if you go back to the oldest OpenBuilds videos, you'll see a requirement for sanding the ends of the lead screws so they will fit into the 8mm ID end block bearings and this sanding was always a tremendous pain. The purpose of the reduced diameter was for the bearing to slip on more easily.
  6. Rink
    Rink Well-Known
    Good evening.
    I’m currently assembling an OpenBuilds LEAD 1515. Today I assembled the Y-axis actuators. One of the lead screws was very tight, but I did manage to get it installed.
    The other was much tighter. Impossible to turn with my hands. I got some rubber gloves, still couldn’t turn it. Tried putting two tension nuts on the end in a “jam-nut” configuration and turning it that way. Didn’t work. Finally, I sprayed some dry-lube on the screw threads and in the nut block. Then I was able to turn it with the rubber gloves on, but only barely and with tremendous effort. It took a long time.
    When squaring the gantry (step 23 in the build video, I think), in order to move the gantry to front of machine on that side, I had to rotate the screw by using a 13mm open end wrench on the tension nut. The other screw rotated by hand with no problem.
    I have two points here:
    1: Despite “customization, the screw/nut block was just too tight in this case. Tight is good, but immovable is not.
    2: I hope it operates properly when completed. Having to disassemble back to this point and reassemble with another screw would be highly frustrating. Having to disassemble even further back to replacing the nut block would be significantly worse. I will spray all the screws with dry-line before I boot it up and jog it for the first time.
    Thx, rink.
  7. David the swarfer
    contact the store ....
  8. Rink
    Rink Well-Known
    Arghhh! Potential disassembly. Blah.
    But I suppose better now than when it’s completely assembled.
    I didn’t use a torque wrench, but I’d estimate about 4 ft/lbs required to turn that screw. I’ll let someone else translate that into stepper motor language.
    Think the nema 23 high-torque motor would turn it ok?
  9. Alex Chambers
    A battery drill probably will - I assume you are talking about unscrewing it for disassembly.
  10. Rink
    Rink Well-Known
    Alex,
    Actually I was wondering if the stepper motor would turn it in normal use. But I doubt it would. Just too tight.
    And being that much tighter than the other one, I would worry about calibration and accuracy issues.
    On tap for today was to install the X-axis lead screw. I’ll try that one as well before contacting the store.
  11. Rink
    Rink Well-Known
    I tried the X-axis and same problem. The lead screw just spins against the hole in the delrin nut block. I have to push very hard to get the threads to engage. When they do engage, then I can’t turn the screw any further.
    With a CNC being a “precision” tool, I would have thought these would be manufactured to very tight tolerances and even checked for fit before leaving the factory. I’m a little surprised.
    I sent a note to http://support.openbuilds.com/support/home
  12. roptics
    roptics New
    I thought about using teflon tape but was concerned about making a high and low side because of the wrap. I used some heat shrink tubing to take up the dead space and it seems well centered. The heat shrink will also "unthread" if I heat it up and need to take it off. At the end of the day I would still rather spin the lead screw in a drill and sand the end to get it to interference fit into the end support bearing.
  13. David the swarfer
    did you actually get the leadscrews and nutblocks from openbuilds store? there are other suppliers that don't always have the same high standards (-:
  14. Rink
    Rink Well-Known
    David, Good evening.
    Yes, sir.
    That post was from a couple months ago.
    I did get them from OpenBuilds, as part of the LEAD 1515 Fully Loaded package.
    I contacted support, they sent me new ones. In the end, I threaded each nut block onto the lead screw individually, making sure to space them appropriately. Then I fastened the nut blocks to the gantry plate. It was difficult since the gantry plate assemblies were already completed and installed on the v-slot extrusions. But with some blue tape and some fiddling I finally got it all together.
    I feel like the nut block threads should be calibrated to start/stop such that you can thread the lead screw through one and then it catches the start of the other one while both blocks are in their fixed (slightly loose) positions. Mine definitely were not calibrated that way. I tried backing the lead screw off and restarting it multiple times, tried from the other end, tried jiggling the slightly loose nut blocks…but they just wouldn’t synch.
    Anyway, up and running now and I love it.
    Thx, rink.
  15. Peter Van Der Walt
    4 start 8mm screw means 90 deg = 2mm of lateral nut movement. With approx 4mm of slot movement for the holes you mount the nuts to, you are guaranteed to hit one of the 4 starts (every 90 deg turn has the chance to enter one of the starts) and still have a little extra room to apply preload. Its impossible to miss if you do the assembly per the video instructions
