artcam 2018 gcode
Discussion in 'OpenBuilds Forum Help' started by Cruiser, Jun 3, 2022.
  1. Cruiser
    Cruiser New
    Hi Everybody
    Im really sorry to ask this question,it must bore you but I cannot find anything up to date.
    I learnt to use artcam 2018 for my designs.
    Then I purchased the OX and the blackbox but soon found out they are not compatible.
    Is there an easy way to export good gcode for the blackbox from artcam 2018?
    I have read that there are some ways but they all seem to be from 2016 or there abouts.
    I wanted to use openbuilds control, not the little black box one.....but the on screen one with the jogger buttons and wizzards.
    I have seen Universal Gcode Sender may work, but would have to ditch the openbuilds control right?.
    I am pretty new to cnc and still trying to figure out all of the steps to create my projects. I hope this made some sort of sense
    Thanks in advance
    Cruiser likes this.
  3. Cruiser
    Cruiser New
    Ooohh thank you Peter!
    Carveco looks great though I don't have the ability to online payments.
    It seems the perfect software though.
    Have you come across any post processor that does work? Im not too technically abled.
    If I do find a post processor.....would that have to replace the openbuilds cam software? I quite like that one and would like to keep using it.
    Thanks again Peter!
    Personally no, but google is your friend and may find something :)
    OpenBuildsCAM is a CAM, ArtCAM is CAM - you pick which one you want to use: See docs:software:overview [OpenBuilds Documentation] and note the first sentence: "Within each of these, you have a lot of freedom to choose which applications you want to make use of in your own preferred workflow. "
    Cruiser likes this.
  5. Cruiser
    Cruiser New
    Thank you, I appreciate all your answers and patience.
    Just one more if you don't mind.
    I've seen I can also edit the code in notepad.
    This man explains the changes to be made to the code.....
    Would this also work?
    Best answer to that would be " You'll have to try it :) "
    We don't use ArtCAM much around here
    Cruiser likes this.
  7. Cruiser
    Cruiser New
    Thank you, Ill test this in a few days once its running properly.
    Does this look correct?
    (I ran the machine once but it ran straight into the side of the machine)
    Code:
    T1M6
    G0Z10.000
    G0X0.000Y0.000S15000M3
    G0X66.250Y94.500Z5.000
    G1Z-0.500F720.0
    G1X65.865Y92.566F2520.0
    X65.394Y90.642
    X64.838Y88.732
    X64.196Y86.844
    X63.470Y84.982
    X62.663Y83.152
    X61.775Y81.359
    X60.811Y79.608
    X59.772Y77.905
    X58.663Y76.254
    X57.488Y74.660
    X56.250Y73.125
    X56.079Y72.948
    X55.859Y72.832
    X55.619Y72.791
    X55.372Y72.827
    X55.152Y72.938
    X55.046Y73.079
    X55.000Y73.250
    X54.911Y74.702
    X54.908Y76.178
    X54.995Y77.669
    X55.175Y79.168
    X55.448Y80.666
    X55.817Y82.155
    X56.280Y83.624
    X56.836Y85.066
    X57.482Y86.472
    X58.214Y87.833
    X59.027Y89.141
    X59.916Y90.391
    X60.874Y91.574
    X61.894Y92.687
    X62.969Y93.725
    X64.090Y94.684
    X65.250Y95.563
    X65.441Y95.638
    X65.649Y95.646
    X65.842Y95.586
    X66.009Y95.461
    X66.123Y95.290
    X66.228Y95.041
    X66.271Y94.770
    X66.250Y94.500
    G0Z5.000
    G0X148.500Y49.813
    G1Z-0.500F720.0
    G1X147.932Y48.152F2520.0
    X147.272Y46.515
    X146.520Y44.909
    X145.680Y43.341
    X144.753Y41.820
    X143.746Y40.351
    X142.661Y38.942
    X141.504Y37.598
    X140.282Y36.324
    X139.000Y35.125
    X138.808Y34.994
    X138.569Y34.931
    X138.323Y34.955
    X138.113Y35.055
    X138.002Y35.176
    X137.939Y35.335
    X137.938Y35.500
    X138.207Y36.885
    X138.563Y38.265
    X139.004Y39.633
    X139.530Y40.981
    X140.141Y42.299
    X140.832Y43.582
    X141.602Y44.821
    X142.445Y46.010
    X143.357Y47.142
    X144.331Y48.211
    X145.361Y49.213
    X146.441Y50.144
    X147.563Y51.000
    X147.763Y51.079
    X147.983Y51.083
    X148.184Y51.012
    X148.353Y50.872
    X148.460Y50.684
    X148.548Y50.402
    X148.562Y50.102
    X148.500Y49.813
    G0Z5.000
    G0X157.500Y115.750
    G1Z-0.500F720.0
    G1X157.426Y113.800F2520.0
    X157.257Y111.851
    X156.992Y109.911
    X156.632Y107.985
    X156.180Y106.082
    X155.636Y104.208
    X154.821Y101.739
    X153.947Y99.289
    X153.014Y96.862
    X152.024Y94.457
    X151.074Y92.294
    X150.037Y90.163
    X148.913Y88.069
    X147.706Y86.018
    X146.418Y84.016
    X145.052Y82.065
    X143.611Y80.172
    X142.098Y78.340
    X140.518Y76.573
    X138.875Y74.875
    X137.602Y73.296
    X136.381Y71.676
    X135.920Y71.149
    X135.422Y70.656
    X135.186Y70.453
    X134.914Y70.294
    X134.621Y70.188
    X134.460Y70.194
    X134.310Y70.267
    X134.204Y70.388
    X134.061Y70.788
    X134.008Y71.209
    X134.017Y71.976
    X134.076Y72.742
    X134.185Y73.502
    X135.084Y78.342
    X136.086Y84.442
    X137.006Y90.555
    X137.478Y93.449
    X138.043Y96.327
    X138.701Y99.185
    X139.451Y102.019
    X140.013Y103.792
    X140.651Y105.541
    X141.364Y107.259
    X142.010Y108.658
    X142.734Y110.027
    X143.536Y111.359
    X144.411Y112.648
    X145.357Y113.888
    X146.369Y115.073
    X147.442Y116.198
    X148.571Y117.258
    X149.750Y118.250
    X150.198Y118.508
    X150.681Y118.705
    X151.186Y118.835
    X151.699Y118.896
    X152.442Y118.944
    X153.194Y118.916
    X153.943Y118.810
    X154.677Y118.627
    X155.384Y118.370
    X156.055Y118.047
    X156.409Y117.812
    X156.730Y117.529
    X157.009Y117.204
    X157.239Y116.847
    X157.384Y116.498
    X157.472Y116.127
    X157.500Y115.750
    G0Z5.000
    G0X9.250Y9.000
    G1Z-0.500F720.0
    G1X9.109Y10.669F2520.0
    X9.054Y12.371
    X9.091Y14.100
    X9.223Y15.849
    X9.452Y17.609
    X9.783Y19.374
    X10.216Y21.135
    X10.751Y22.883
    X11.389Y24.608
    X12.128Y26.303
    X12.966Y27.958
    X13.899Y29.565
    X14.923Y31.115
    X16.033Y32.601
    X17.222Y34.017
    X18.484Y35.356
    X19.811Y36.613
    X21.195Y37.784
    X22.629Y38.865
    X24.104Y39.854
    X25.612Y40.749
    X27.144Y41.551
    X28.692Y42.259
    X30.250Y42.875
    X30.569Y42.962
    X30.918Y42.976
    X31.271Y42.906
    X31.597Y42.755
    X31.871Y42.538
    X32.078Y42.280
    X32.209Y41.964
    X32.250Y41.625
    X32.189Y39.798
    X32.039Y37.954
    X31.797Y36.099
    X31.463Y34.240
    X31.034Y32.383
    X30.510Y30.536
    X29.890Y28.706
    X29.177Y26.901
    X28.369Y25.126
    X27.472Y23.390
    X26.486Y21.700
    X25.416Y20.062
    X24.266Y18.482
    X23.040Y16.966
    X21.745Y15.519
    X20.386Y14.145
    X18.969Y12.850
    X17.501Y11.635
    X15.988Y10.504
    X14.438Y9.458
    X12.856Y8.498
    X11.250Y7.625
    X10.939Y7.524
    X10.593Y7.506
    X10.250Y7.583
    X9.946Y7.747
    X9.708Y7.972
    X9.485Y8.279
    X9.329Y8.629
    X9.250Y9.000
    G0Z5.000
    G0X42.500Y55.063
    G1Z-0.500F720.0
    G1X46.426Y58.315F2520.0
    X50.301Y61.628
    X54.125Y65.000
    X54.266Y65.245
    X54.275Y65.463
    X54.237Y65.680
    X54.155Y65.883
    X53.210Y67.546
    X52.768Y68.593
    X52.394Y69.667
    X52.092Y70.762
    X51.757Y72.189
    X51.502Y73.659
    X51.333Y75.163
    X51.254Y76.696
    X51.270Y78.249
    X51.384Y79.814
    X51.596Y81.380
    X51.909Y82.939
    X52.322Y84.482
    X52.833Y85.999
    X53.440Y87.479
    X54.138Y88.916
    X54.922Y90.299
    X55.787Y91.622
    X56.726Y92.879
    X57.731Y94.063
    X58.794Y95.170
    X59.907Y96.197
    X61.062Y97.140
    X62.250Y98.000
    X62.875Y98.394
    X63.547Y98.720
    X64.257Y98.972
    X64.990Y99.142
    X65.732Y99.229
    X66.471Y99.234
    X67.049Y99.171
    X67.621Y99.029
    X68.170Y98.808
    X68.681Y98.514
    X69.142Y98.159
    X69.435Y97.841
    X69.681Y97.471
    X69.866Y97.060
    X69.982Y96.625
    X70.026Y96.182
    X70.000Y95.750
    X69.658Y93.425
    X69.231Y91.106
    X68.720Y88.798
    X68.125Y86.506
    X67.447Y84.233
    X66.686Y81.985
    X65.845Y79.766
    X64.925Y77.580
    X63.928Y75.432
    X62.857Y73.325
    X61.713Y71.263
    X60.500Y69.250
    X60.400Y69.002
    X60.466Y68.824
    X60.698Y68.680
    X61.864Y68.299
    X63.005Y67.844
    X64.115Y67.315
    X65.186Y66.716
    X66.084Y66.120
    X66.941Y65.463
    X67.750Y64.750
    X68.204Y63.836
    X68.587Y62.870
    X68.892Y61.860
    X69.111Y60.816
    X69.240Y59.749
    X69.276Y58.671
    X69.218Y57.594
    X69.067Y56.530
    X68.826Y55.491
    X68.501Y54.487
    X68.098Y53.529
    X67.625Y52.625
    X67.335Y51.491
    X66.966Y50.379
    X66.520Y49.297
    X66.090Y48.456
    X65.742Y47.578
    X62.915Y38.177
    X62.478Y37.043
    X61.954Y35.947
    X61.326Y34.353
    X60.785Y32.719
    X60.334Y31.052
    X59.977Y29.360
    X59.714Y27.651
    X59.547Y25.933
    X59.476Y24.213
    X59.500Y22.500
    X59.532Y21.969
    X59.610Y21.442
    X59.734Y20.924
    X59.835Y20.639
    X59.983Y20.372
    X60.172Y20.137
    X60.327Y20.016
    X60.520Y19.964
    X60.711Y19.990
    X60.884Y20.092
    X61.000Y20.250
    X65.658Y29.159
    X70.399Y38.026
    X75.222Y46.848
    X80.125Y55.625
    X80.989Y56.955
    X81.788Y58.335
    X82.519Y59.759
    X83.179Y61.222
    X83.763Y62.719
    X84.271Y64.244
    X84.699Y65.790
    X85.047Y67.353
    X85.314Y68.925
    X85.500Y70.500
    X85.587Y70.916
    X85.770Y71.322
    X86.046Y71.687
    X86.397Y71.980
    X86.794Y72.183
    X87.204Y72.291
    X87.672Y72.342
    X88.149Y72.297
    X88.607Y72.155
    X89.019Y71.929
    X89.377Y71.625
    X89.673Y71.247
    X89.885Y70.816
    X90.004Y70.362
    X90.054Y69.909
    X90.053Y69.452
    X90.000Y69.000
    X89.301Y64.267
    X88.693Y59.522
    X88.176Y54.765
    X87.750Y50.000
    X87.755Y48.953
    X87.929Y48.174
    X88.047Y47.909
    X88.209Y47.666
    X88.408Y47.455
    X88.650Y47.298
    X88.930Y47.211
    X89.218Y47.203
    X89.456Y47.260
    X89.679Y47.377
    X89.865Y47.546
    X90.000Y47.750
    X92.007Y51.790
    X94.084Y55.795
    X96.232Y59.765
    X98.448Y63.697
    X100.732Y67.590
    X103.083Y71.441
    X105.500Y75.250
    X105.852Y75.756
    X106.262Y76.221
    X106.722Y76.637
    X107.223Y76.995
    X107.658Y77.234
    X108.142Y77.410
    X108.659Y77.512
    X109.192Y77.532
    X109.722Y77.468
    X110.228Y77.322
    X110.695Y77.106
    X111.109Y76.832
    X111.431Y76.541
    X111.709Y76.186
    X111.925Y75.777
    X112.065Y75.332
    X112.122Y74.874
    X112.098Y74.423
    X112.000Y74.000
    X111.016Y70.863
    X110.122Y67.691
    X109.318Y64.488
    X108.607Y61.259
    X107.990Y58.006
    X107.468Y54.735
    X107.041Y51.450
    X106.710Y48.154
    X106.476Y44.852
    X106.338Y41.548
    X106.296Y38.246
    X106.351Y34.951
    X106.500Y31.667
    X106.543Y31.192
    X106.674Y30.721
    X106.892Y30.279
    X107.185Y29.887
    X107.534Y29.564
    X107.891Y29.365
    X108.286Y29.247
    X108.693Y29.218
    X109.023Y29.264
    X109.346Y29.393
    X109.631Y29.601
    X109.854Y29.868
    X110.000Y30.167
    X111.348Y33.892
    X112.788Y37.587
    X114.319Y41.249
    X115.939Y44.874
    X117.648Y48.459
    X119.443Y52.000
    X121.324Y55.495
    X123.288Y58.940
    X125.333Y62.333
    X125.679Y62.957
    X125.970Y63.610
    X126.203Y64.285
    X126.485Y65.473
    X126.672Y66.681
    X126.760Y67.899
    X126.883Y72.488
    X127.000Y74.000
    X127.558Y78.725
    X128.207Y83.438
    X128.689Y86.547
    X129.257Y89.643
    X129.912Y92.722
    X130.652Y95.782
    X131.477Y98.818
    X132.207Y101.167
    X133.026Y103.488
    X133.935Y105.778
    X134.930Y108.030
    X136.010Y110.240
    X136.922Y111.922
    X137.901Y113.567
    X138.943Y115.173
    X140.046Y116.736
    X141.160Y118.201
    X142.348Y119.606
    X143.608Y120.947
    X144.314Y121.545
    X145.077Y122.081
    X145.888Y122.550
    X146.738Y122.944
    X147.616Y123.260
    X148.511Y123.495
    X149.491Y123.665
    X150.486Y123.765
    X151.489Y123.791
    X152.491Y123.745
    X153.484Y123.627
    X154.461Y123.438
    X155.461Y123.188
    X156.442Y122.857
    X157.395Y122.448
    X158.311Y121.964
    X159.181Y121.411
    X159.689Y121.011
    X160.151Y120.555
    X160.557Y120.051
    X160.752Y119.740
    X160.895Y119.396
    X160.978Y119.033
    X161.000Y118.667
    X160.616Y114.190
    X160.315Y111.571
    X159.937Y108.962
    X159.483Y106.365
    X158.718Y102.925
    X158.196Y100.982
    X157.593Y99.058
    X156.909Y97.157
    X156.148Y95.286
    X155.311Y93.449
    X154.399Y91.650
    X153.416Y89.894
    X152.378Y88.199
    X151.291Y86.534
    X150.157Y84.900
    X148.977Y83.300
    X146.800Y80.488
    X144.556Y77.728
    X135.567Y67.063
    X134.365Y65.416
    X133.558Y64.065
    X133.088Y63.006
    X132.900Y62.236
    X132.879Y62.021
    X132.920Y61.805
    X133.018Y61.612
    X133.153Y61.544
    X133.312Y61.545
    X133.446Y61.613
    X136.157Y63.984
    X137.471Y65.033
    X138.847Y66.003
    X140.278Y66.890
    X141.757Y67.689
    X142.771Y68.147
    X143.813Y68.543
    X144.875Y68.875
    X145.626Y69.035
    X146.403Y69.117
    X147.192Y69.117
    X147.982Y69.033
    X148.758Y68.865
    X149.508Y68.617
    X150.220Y68.295
    X150.882Y67.907
    X151.616Y67.384
    X152.303Y66.786
    X152.934Y66.118
    X153.497Y65.391
    X153.986Y64.614
    X154.393Y63.798
    X154.717Y62.958
    X155.018Y61.839
    X155.233Y60.700
    X155.405Y60.468
    X155.520Y60.410
    X155.647Y60.422
    X155.750Y60.500
    X156.970Y61.959
    X158.269Y63.358
    X159.641Y64.690
    X161.081Y65.950
    X162.583Y67.133
    X164.142Y68.234
    X165.750Y69.250
    X165.929Y69.342
    X166.137Y69.364
    X166.332Y69.313
    X166.496Y69.196
    X166.612Y69.023
    X166.657Y68.826
    X166.615Y68.646
    X166.500Y68.500
    X164.799Y66.993
    X163.156Y65.418
    X161.576Y63.777
    X160.063Y62.074
    X158.620Y60.313
    X157.250Y58.500
    X156.643Y57.850
    X155.998Y57.238
    X155.849Y57.007
    X155.750Y56.750
    X155.202Y54.811
    X154.564Y52.885
    X153.836Y50.978
    X153.019Y49.095
    X152.114Y47.244
    X151.123Y45.430
    X150.048Y43.660
    X148.893Y41.938
    X147.660Y40.271
    X146.354Y38.664
    X144.980Y37.121
    X143.541Y35.646
    X142.043Y34.243
    X140.491Y32.916
    X138.892Y31.668
    X137.250Y30.500
    X136.772Y30.223
    X136.252Y30.024
    X135.710Y29.912
    X134.987Y29.919
    X134.568Y30.011
    X134.169Y30.180
    X133.811Y30.416
    X133.428Y30.857
    X133.302Y31.121
    X133.227Y31.411
    X133.210Y31.709
    X133.250Y32.000
    X133.604Y33.450
    X134.034Y34.884
    X134.539Y36.295
    X135.117Y37.678
    X135.765Y39.027
    X136.481Y40.337
    X137.399Y41.866
    X138.380Y43.357
    X139.419Y44.806
    X141.649Y47.651
    X145.233Y51.851
    X148.875Y56.000
    X149.225Y56.585
    X149.506Y57.210
    X149.713Y57.865
    X149.841Y58.534
    X149.982Y59.379
    X150.057Y60.236
    X150.064Y61.098
    X150.004Y61.957
    X149.877Y62.804
    X149.661Y63.511
    X149.487Y63.893
    X149.247Y64.241
    X148.954Y64.542
    X148.623Y64.729
    X148.247Y64.846
    X147.850Y64.878
    X147.460Y64.823
    X147.104Y64.691
    X146.250Y64.250
    X144.674Y63.212
    X143.149Y62.090
    X141.681Y60.889
    X140.275Y59.612
    X138.939Y58.266
    X137.676Y56.855
    X136.491Y55.386
    X135.547Y54.063
    X134.678Y52.683
    X133.888Y51.253
    X133.182Y49.780
    X132.562Y48.271
    X132.031Y46.734
    X131.669Y45.437
    X131.351Y44.127
    X131.077Y42.807
    X130.883Y42.292
    X130.604Y41.798
    X130.243Y41.346
    X129.812Y40.955
    X129.326Y40.640
    X128.807Y40.410
    X128.275Y40.268
    X127.814Y40.217
    X127.336Y40.247
    X126.864Y40.365
    X126.421Y40.566
    X126.027Y40.838
    X125.697Y41.165
    X125.508Y41.442
    X125.358Y41.744
    X125.250Y42.063
    X124.984Y43.188
    X124.796Y44.336
    X124.688Y45.498
    X124.660Y46.667
    X124.715Y47.833
    X124.849Y48.989
    X125.063Y50.125
    X125.220Y50.986
    X125.282Y51.860
    X125.271Y52.192
    X125.214Y52.521
    X125.114Y52.838
    X125.038Y52.987
    X124.915Y53.107
    X124.764Y53.179
    X124.635Y53.166
    X124.517Y53.102
    X124.438Y53.000
    X123.524Y51.437
    X122.686Y49.826
    X121.928Y48.171
    X121.253Y46.480
    X120.664Y44.758
    X120.163Y43.013
    X119.750Y41.250
    X119.475Y40.635
    X119.250Y40.000
    X118.986Y38.503
    X118.627Y37.008
    X118.175Y35.524
    X117.628Y34.059
    X116.987Y32.623
    X116.256Y31.223
    X115.438Y29.869
    X114.537Y28.569
    X113.558Y27.330
    X112.509Y26.159
    X111.395Y25.061
    X110.226Y24.041
    X109.008Y23.103
    X107.750Y22.250
    X107.355Y22.059
    X106.915Y21.949
    X106.457Y21.935
    X106.010Y22.015
    X105.603Y22.180
    X105.184Y22.435
    X104.801Y22.755
    X104.470Y23.132
    X104.200Y23.552
    X104.000Y24.000
    X103.295Y26.013
    X102.668Y28.067
    X102.122Y30.156
    X101.660Y32.277
    X101.283Y34.425
    X100.995Y36.594
    X100.796Y38.778
    X100.687Y40.973
    X100.670Y43.172
    X100.745Y45.370
    X100.911Y47.561
    X101.166Y49.739
    X101.511Y51.900
    X101.944Y54.037
    X102.462Y56.145
    X103.062Y58.220
    X103.743Y60.256
    X104.500Y62.250
    X104.596Y62.539
    X104.638Y62.841
    X104.628Y63.001
    X104.572Y63.154
    X104.476Y63.282
    X104.306Y63.310
    X104.250Y63.250
    X102.870Y60.368
    X101.419Y57.519
    X99.899Y54.705
    X98.311Y51.929
    X96.657Y49.193
    X94.938Y46.500
    X94.464Y45.873
    X93.906Y45.294
    X93.271Y44.781
    X92.571Y44.347
    X91.823Y44.004
    X91.044Y43.759
    X90.253Y43.615
    X89.469Y43.568
    X88.684Y43.615
    X87.893Y43.759
    X87.114Y44.004
    X86.366Y44.347
    X85.667Y44.781
    X85.032Y45.294
    X84.473Y45.873
    X84.000Y46.500
    X83.547Y47.205
    X83.165Y47.955
    X82.859Y48.739
    X82.633Y49.546
    X82.560Y50.083
    X82.578Y50.629
    X82.685Y51.161
    X81.093Y48.901
    X79.573Y46.585
    X78.129Y44.219
    X76.764Y41.804
    X75.479Y39.346
    X74.276Y36.848
    X73.158Y34.315
    X72.125Y31.750
    X70.903Y29.179
    X69.592Y26.646
    X68.196Y24.157
    X66.714Y21.714
    X65.151Y19.324
    X63.509Y16.988
    X61.791Y14.713
    X60.000Y12.500
    X59.806Y12.285
    X59.578Y12.103
    X59.327Y11.960
    X59.064Y11.888
    X58.778Y11.884
    X58.496Y11.957
    X58.247Y12.099
    X58.052Y12.290
    X57.751Y12.674
    X57.497Y13.094
    X57.297Y13.540
    X56.835Y14.932
    X56.448Y16.819
    X56.146Y18.724
    X55.932Y20.640
    X55.805Y22.562
    X55.710Y24.856
    X55.702Y27.159
    X55.780Y29.467
    X55.945Y31.774
    X56.198Y34.076
    X56.538Y36.367
    X56.963Y38.643
    X57.474Y40.899
    X58.068Y43.130
    X58.744Y45.332
    X59.500Y47.500
    X60.556Y50.334
    X61.534Y53.198
    X62.432Y56.088
    X63.250Y59.000
    X63.391Y59.621
    X63.455Y60.268
    X63.435Y60.925
    X63.329Y61.578
    X63.141Y62.208
    X62.877Y62.802
    X62.547Y63.347
    X62.157Y63.833
    X61.687Y64.264
    X61.149Y64.622
    X60.562Y64.891
    X59.948Y65.065
    X59.329Y65.141
    X58.825Y65.111
    X58.323Y65.003
    X57.841Y64.819
    X57.395Y64.564
    X57.000Y64.250
    X53.966Y61.229
    X50.881Y58.259
    X47.746Y55.341
    X44.563Y52.477
    X41.333Y49.667
    X41.168Y49.434
    X41.057Y49.171
    X40.751Y48.113
    X40.528Y47.034
    X40.192Y45.007
    X39.924Y42.969
    X39.494Y38.407
    X39.188Y36.197
    X38.787Y33.995
    X38.289Y31.807
    X37.697Y29.640
    X37.012Y27.499
    X36.235Y25.391
    X35.369Y23.321
    X34.416Y21.295
    X33.382Y19.319
    X32.524Y17.837
    X31.611Y16.388
    X30.643Y14.974
    X29.623Y13.597
    X28.552Y12.262
    X27.311Y10.842
    X26.003Y9.480
    X24.635Y8.182
    X23.402Y7.100
    X22.115Y6.076
    X20.778Y5.115
    X19.396Y4.220
    X17.974Y3.395
    X16.517Y2.640
    X15.543Y2.245
    X14.534Y1.927
    X13.499Y1.690
    X12.448Y1.537
    X11.392Y1.470
    X10.340Y1.487
    X9.453Y1.580
    X8.574Y1.763
    X7.714Y2.032
    X6.888Y2.385
    X6.107Y2.816
    X5.518Y3.233
    X4.968Y3.714
    X4.468Y4.252
    X4.026Y4.838
    X3.649Y5.464
    X3.341Y6.117
    X3.068Y6.891
    X2.870Y7.689
    X2.750Y8.500
    X2.626Y10.172
    X2.591Y11.857
    X2.646Y13.549
    X2.791Y15.240
    X3.027Y16.924
    X3.352Y18.593
    X3.766Y20.239
    X4.265Y21.857
    X4.847Y23.439
    X5.508Y24.979
    X6.354Y26.709
    X7.280Y28.404
    X8.284Y30.059
    X9.362Y31.669
    X10.512Y33.229
    X11.730Y34.733
    X13.011Y36.178
    X14.353Y37.560
    X16.022Y39.147
    X17.760Y40.669
    X19.564Y42.122
    X21.429Y43.502
    X23.350Y44.806
    X25.324Y46.030
    X27.345Y47.170
    X29.407Y48.225
    X31.505Y49.193
    X33.634Y50.070
    X33.800Y50.238
    X33.914Y50.446
    X34.125Y51.125
    X34.663Y53.322
    X35.132Y55.536
    X35.533Y57.764
    X35.864Y60.003
    X36.125Y62.250
    X36.093Y62.450
    X35.989Y62.632
    X35.833Y62.762
    X35.642Y62.829
    X35.433Y62.826
    X35.245Y62.751
    X35.030Y62.592
    X34.875Y62.375
    X34.004Y60.826
    X33.053Y59.307
    X32.023Y57.826
    X30.915Y56.387
    X29.734Y54.998
    X28.481Y53.662
    X27.162Y52.387
    X25.780Y51.177
    X24.340Y50.036
    X22.848Y48.968
    X21.309Y47.977
    X19.729Y47.065
    X18.114Y46.235
    X16.471Y45.489
    X14.806Y44.827
    X13.125Y44.250
    X12.578Y44.127
    X12.003Y44.092
    X11.423Y44.151
    X10.860Y44.304
    X10.337Y44.543
    X9.870Y44.854
    X9.281Y45.378
    X8.750Y45.971
    X8.289Y46.623
    X7.906Y47.322
    X7.608Y48.052
    X7.372Y48.768
    X7.191Y49.503
    X7.067Y50.249
    X7.000Y51.000
    X6.910Y53.604
    X6.910Y56.224
    X7.002Y58.854
    X7.187Y61.490
    X7.465Y64.127
    X7.837Y66.759
    X8.302Y69.383
    X8.861Y71.993
    X9.513Y74.583
    X10.256Y77.150
    X11.090Y79.688
    X12.012Y82.193
    X13.021Y84.659
    X14.114Y87.083
    X15.288Y89.460
    X16.541Y91.787
    X17.868Y94.059
    X19.268Y96.273
    X20.736Y98.426
    X25.375Y104.750
    X25.990Y105.511
    X26.689Y106.226
    X27.468Y106.883
    X28.319Y107.468
    X29.230Y107.971
    X30.191Y108.382
    X31.187Y108.696
    X32.203Y108.908
    X33.223Y109.018
    X34.233Y109.028
    X35.219Y108.944
    X36.176Y108.771
    X37.130Y108.505
    X38.072Y108.143
    X38.990Y107.683
    X39.867Y107.129
    X40.691Y106.488
    X41.447Y105.767
    X42.126Y104.977
    X42.718Y104.131
    X43.218Y103.244
    X43.623Y102.329
    X43.933Y101.401
    X44.036Y100.990
    X44.075Y100.561
    X44.046Y100.128
    X43.949Y99.707
    X43.792Y99.314
    X43.590Y99.042
    X43.318Y98.822
    X43.001Y98.676
    X42.668Y98.613
    X42.181Y98.682
    X41.965Y98.785
    X41.774Y98.937
    X41.625Y99.125
    X41.149Y99.813
    X40.588Y100.453
    X39.949Y101.032
    X39.243Y101.534
    X38.485Y101.949
    X37.690Y102.271
    X36.876Y102.496
    X36.055Y102.625
    X35.211Y102.661
    X34.356Y102.599
    X33.506Y102.436
    X32.680Y102.175
    X31.895Y101.821
    X31.164Y101.383
    X30.500Y100.875
    X30.003Y100.307
    X29.568Y99.690
    X26.250Y94.469
    X24.878Y92.432
    X23.574Y90.337
    X22.341Y88.187
    X21.183Y85.985
    X20.104Y83.735
    X19.105Y81.442
    X18.190Y79.109
    X17.360Y76.743
    X16.618Y74.346
    X15.964Y71.924
    X15.401Y69.483
    X14.929Y67.027
    X14.547Y64.561
    X14.258Y62.090
    X14.059Y59.619
    X13.950Y57.154
    X13.931Y54.698
    X13.992Y53.365
    X13.997Y52.029
    X13.947Y50.695
    X13.975Y50.509
    X14.087Y50.345
    X14.250Y50.250
    X15.072Y50.140
    X15.907Y50.127
    X16.737Y50.214
    X17.546Y50.397
    X18.606Y50.753
    X19.634Y51.197
    X20.621Y51.723
    X22.500Y52.875
    X23.415Y53.505
    X24.293Y54.184
    X25.555Y55.304
    X26.759Y56.490
    X27.900Y57.735
    X28.975Y59.036
    X35.116Y67.056
    X36.875Y69.563
    X35.418Y69.543
    X33.960Y69.443
    X32.508Y69.263
    X31.068Y69.003
    X29.646Y68.665
    X28.250Y68.250
    X27.573Y68.319
    X26.904Y68.471
    X26.259Y68.703
    X25.652Y69.011
    X25.205Y69.239
    X24.790Y69.527
    X24.419Y69.866
    X24.391Y69.938
    X24.438Y70.000
    X26.256Y70.758
    X28.115Y71.438
    X30.010Y72.037
    X31.936Y72.552
    X33.887Y72.981
    X35.858Y73.322
    X37.841Y73.575
    X39.832Y73.737
    X41.825Y73.811
    X43.812Y73.795
    X45.789Y73.691
    X47.750Y73.500
    X48.264Y73.424
    X48.761Y73.257
    X49.217Y73.009
    X49.387Y72.849
    X49.516Y72.638
    X49.583Y72.395
    X49.580Y72.149
    X49.516Y71.924
    X49.363Y71.622
    X49.157Y71.353
    X48.776Y70.998
    X48.340Y70.709
    X47.866Y70.496
    X47.496Y70.393
    X47.114Y70.348
    X45.606Y70.367
    X45.054Y70.311
    X44.805Y70.225
    X44.583Y70.083
    X44.252Y69.721
    X43.967Y69.313
    X43.739Y68.868
    X43.573Y68.399
    X43.473Y67.918
    X42.890Y64.072
    X42.681Y61.510
    X42.605Y58.286
    X42.500Y55.063
    G0Z5.000
    G0X286.063Y35.875
    G1Z-0.500F720.0
    G1X285.455Y35.527F2520.0
    X285.286Y35.492
    X285.123Y35.551
    X285.046Y35.718
    X285.045Y35.903
    X285.161Y36.425
    X285.329Y36.934
    X285.548Y37.422
    X286.434Y39.128
    X287.397Y40.795
    X288.434Y42.417
    X289.543Y43.988
    X290.565Y45.379
    X291.645Y46.726
    X292.780Y48.028
    X293.968Y49.279
    X294.627Y49.899
    X295.327Y50.474
    X296.063Y51.000
    X296.574Y51.234
    X296.733Y51.249
    X296.889Y51.182
    X296.986Y51.055
    X297.037Y50.690
    X296.997Y50.324
    X296.723Y49.381
    X296.367Y48.463
    X295.931Y47.582
    X295.121Y46.126
    X294.243Y44.705
    X293.299Y43.323
    X292.291Y41.985
    X291.224Y40.696
    X290.100Y39.459
    X288.924Y38.279
    X288.007Y37.435
    X287.052Y36.633
    X286.063Y35.875
    G0Z5.000
    G0X282.750Y81.750
    G1Z-0.500F720.0
    G1X283.416Y85.313F2520.0
    X284.160Y88.863
    X284.980Y92.397
    X285.878Y95.912
    X286.851Y99.405
    X287.900Y102.876
    X288.611Y105.079
    X289.390Y107.260
    X290.235Y109.415
    X290.710Y110.473
    X291.250Y111.500
    X292.073Y112.863
    X292.946Y114.194
    X293.869Y115.491
    X294.619Y116.461
    X295.447Y117.370
    X296.346Y118.209
    X297.308Y118.969
    X297.832Y119.304
    X298.395Y119.581
    X298.987Y119.794
    X299.598Y119.939
    X300.215Y120.014
    X300.817Y119.995
    X301.420Y119.896
    X302.007Y119.717
    X302.562Y119.463
    X303.072Y119.142
    X303.442Y118.778
    X303.760Y118.358
    X304.015Y117.892
    X304.197Y117.397
    X304.303Y116.890
    X304.394Y116.153
    X304.413Y115.410
    X304.307Y114.033
    X304.104Y112.664
    X303.804Y111.316
    X300.958Y100.304
    X300.149Y97.314
    X299.261Y94.344
    X298.294Y91.400
    X297.249Y88.483
    X296.517Y86.666
    X295.714Y84.878
    X294.841Y83.125
    X294.231Y82.000
    X293.557Y80.908
    X292.823Y79.855
    X292.031Y78.845
    X291.186Y77.884
    X290.573Y77.280
    X289.909Y76.727
    X289.198Y76.231
    X288.450Y75.798
    X287.671Y75.431
    X286.943Y75.184
    X286.188Y75.014
    X285.419Y74.924
    X284.650Y74.915
    X283.902Y74.983
    X283.162Y75.115
    X282.438Y75.313
    X282.134Y75.458
    X281.866Y75.690
    X281.666Y75.991
    X281.557Y76.329
    X281.541Y76.664
    X281.578Y77.329
    X281.703Y77.982
    X282.554Y80.897
    X282.750Y81.750
    G0Z5.000
    G0X164.000Y15.750
    G1Z-0.500F720.0
    G1X163.577Y16.802F2520.0
    X163.214Y17.878
    X162.911Y18.971
    X162.675Y20.080
    X162.518Y21.205
    X162.442Y22.336
    X162.444Y23.314
    X162.541Y24.293
    X162.732Y25.261
    X163.016Y26.204
    X163.385Y27.108
    X163.782Y27.826
    X164.250Y28.500
    X166.224Y31.058
    X168.245Y33.580
    X170.312Y36.064
    X172.425Y38.509
    X174.191Y40.455
    X176.025Y42.343
    X177.924Y44.167
    X179.884Y45.925
    X181.902Y47.614
    X183.975Y49.230
    X185.943Y50.632
    X187.964Y51.961
    X190.035Y53.214
    X192.151Y54.390
    X194.307Y55.486
    X196.500Y56.500
    X196.932Y56.679
    X197.381Y56.816
    X197.839Y56.909
    X198.149Y56.931
    X198.461Y56.891
    X198.756Y56.791
    X198.978Y56.638
    X199.160Y56.435
    X199.289Y56.199
    X199.433Y55.703
    X199.480Y55.190
    X199.455Y54.502
    X199.367Y53.819
    X199.107Y52.601
    X198.781Y51.398
    X198.391Y50.215
    X197.575Y48.007
    X196.680Y45.830
    X194.553Y41.109
    X189.500Y30.750
    X188.677Y29.108
    X187.768Y27.506
    X186.777Y25.951
    X185.707Y24.449
    X184.563Y23.006
    X183.350Y21.627
    X182.322Y20.581
    X181.231Y19.593
    X180.083Y18.667
    X178.884Y17.810
    X177.640Y17.024
    X176.356Y16.314
    X175.202Y15.769
    X174.012Y15.292
    X172.792Y14.885
    X171.550Y14.551
    X170.291Y14.292
    X169.022Y14.108
    X167.750Y14.000
    X167.189Y13.985
    X166.625Y14.038
    X166.069Y14.158
    X165.533Y14.344
    X165.028Y14.589
    X164.709Y14.815
    X164.424Y15.090
    X164.185Y15.406
    X164.000Y15.750
    G0Z5.000
    G0X272.250Y51.750
    G1Z-0.500F720.0
    G1X271.792Y51.421F2520.0
    X271.641Y51.288
    X271.538Y51.107
    X271.501Y50.908
    X271.453Y50.074
    X271.355Y49.243
    X271.206Y48.421
    X270.636Y46.158
    X269.983Y43.916
    X269.248Y41.700
    X268.432Y39.514
    X267.721Y37.780
    X266.937Y36.077
    X266.081Y34.410
    X264.513Y31.622
    X262.875Y28.875
    X262.362Y28.122
    X261.804Y27.400
    X261.204Y26.715
    X260.391Y25.863
    X259.530Y25.058
    X258.625Y24.306
    X257.985Y23.825
    X257.299Y23.406
    X256.577Y23.054
    X255.827Y22.774
    X255.412Y22.684
    X254.985Y22.656
    X254.562Y22.691
    X254.173Y22.802
    X253.812Y22.992
    X253.500Y23.250
    X252.928Y23.852
    X252.405Y24.499
    X251.935Y25.184
    X251.598Y25.783
    X251.306Y26.405
    X251.059Y27.046
    X250.080Y30.222
    X249.496Y31.810
    X249.000Y33.428
    X248.689Y34.789
    X248.458Y36.166
    X248.308Y37.553
    X248.223Y39.317
    X248.215Y41.086
    X248.282Y42.854
    X248.426Y44.617
    X248.644Y46.370
    X248.979Y48.563
    X249.375Y50.746
    X249.833Y52.917
    X251.132Y58.342
    X252.500Y63.750
    X252.836Y65.234
    X253.118Y66.729
    X253.344Y68.234
    X253.373Y68.623
    X253.321Y69.011
    X253.280Y69.068
    X253.211Y69.082
    X253.040Y68.959
    X252.534Y68.188
    X251.831Y66.808
    X249.106Y60.734
    X246.451Y54.629
    X245.301Y52.080
    X244.092Y49.557
    X242.825Y47.064
    X242.065Y45.702
    X241.226Y44.387
    X240.988Y44.032
    X240.709Y43.707
    X240.396Y43.417
    X240.053Y43.234
    X239.677Y43.108
    X239.284Y43.044
    X238.887Y43.046
    X238.505Y43.112
    X237.978Y43.259
    X237.472Y43.473
    X237.000Y43.750
    X236.084Y44.415
    X235.203Y45.165
    X234.367Y45.999
    X233.588Y46.912
    X232.875Y47.899
    X232.240Y48.952
    X231.690Y50.061
    X231.234Y51.217
    X230.875Y52.407
    X230.618Y53.618
    X230.464Y54.838
    X230.411Y56.053
    X230.456Y57.253
    X230.595Y58.426
    X230.821Y59.561
    X231.127Y60.650
    X231.481Y61.620
    X231.887Y62.571
    X232.341Y63.498
    X232.327Y63.827
    X232.213Y64.152
    X232.008Y64.429
    X231.743Y64.624
    X231.383Y64.795
    X230.973Y64.887
    X230.541Y64.882
    X230.123Y64.778
    X229.749Y64.585
    X229.444Y64.328
    X229.075Y63.898
    X228.773Y63.414
    X228.547Y62.894
    X227.758Y60.698
    X227.057Y58.464
    X226.448Y56.199
    X225.933Y53.907
    X225.513Y51.595
    X225.189Y49.268
    X224.962Y46.933
    X224.832Y44.595
    X224.799Y42.262
    X224.962Y36.339
    X225.121Y34.566
    X225.086Y34.030
    X224.963Y33.493
    X224.750Y32.977
    X224.456Y32.502
    X224.093Y32.088
    X223.679Y31.746
    X223.227Y31.489
    X222.717Y31.297
    X222.163Y31.187
    X221.586Y31.171
    X221.011Y31.255
    X220.463Y31.434
    X219.963Y31.697
    X219.529Y32.027
    X219.170Y32.402
    X218.863Y32.820
    X218.607Y33.272
    X218.406Y33.750
    X217.687Y35.688
    X217.420Y36.700
    X217.349Y37.201
    X217.333Y37.706
    X217.553Y42.790
    X217.868Y47.870
    X218.279Y52.943
    X218.785Y58.008
    X219.386Y63.061
    X219.359Y63.162
    X219.264Y63.204
    X217.130Y62.857
    X215.004Y62.465
    X212.886Y62.028
    X210.908Y61.558
    X208.944Y61.028
    X208.401Y60.858
    X207.873Y60.608
    X207.378Y60.283
    X206.932Y59.888
    X206.548Y59.437
    X206.236Y58.944
    X206.000Y58.426
    X204.798Y54.537
    X203.682Y50.623
    X202.653Y46.685
    X201.777Y43.494
    X200.825Y40.325
    X199.798Y37.179
    X199.023Y35.017
    X198.179Y32.880
    X197.268Y30.770
    X196.291Y28.690
    X195.249Y26.644
    X194.346Y25.013
    X193.379Y23.417
    X192.350Y21.858
    X191.262Y20.341
    X190.115Y18.868
    X188.915Y17.443
    X187.973Y16.418
    X186.995Y15.428
    X185.983Y14.473
    X184.729Y13.382
    X183.424Y12.347
    X182.071Y11.372
    X180.674Y10.461
    X179.239Y9.616
    X177.770Y8.838
    X177.229Y8.616
    X176.664Y8.464
    X175.462Y8.300
    X174.253Y8.216
    X171.307Y7.835
    X170.020Y7.726
    X168.728Y7.684
    X167.435Y7.709
    X166.147Y7.801
    X165.119Y7.922
    X164.100Y8.125
    X163.098Y8.408
    X162.124Y8.769
    X161.185Y9.203
    X160.532Y9.597
    X159.923Y10.071
    X159.374Y10.617
    X158.897Y11.223
    X158.500Y11.875
    X157.890Y13.099
    X157.358Y14.363
    X156.908Y15.661
    X156.542Y16.983
    X156.262Y18.321
    X156.131Y19.563
    X156.096Y20.818
    X156.159Y22.076
    X156.319Y23.325
    X156.575Y24.555
    X156.923Y25.754
    X157.487Y27.323
    X158.118Y28.870
    X158.816Y30.390
    X159.578Y31.878
    X160.401Y33.332
    X161.285Y34.747
    X162.298Y36.262
    X163.368Y37.740
    X164.493Y39.178
    X165.671Y40.572
    X166.898Y41.920
    X168.613Y43.652
    X170.399Y45.316
    X172.251Y46.907
    X174.164Y48.422
    X176.135Y49.856
    X178.286Y51.305
    X180.480Y52.691
    X182.715Y54.014
    X184.986Y55.271
    X187.293Y56.461
    X189.631Y57.583
    X192.494Y58.883
    X195.389Y60.112
    X196.025Y60.408
    X196.629Y60.785
    X197.187Y61.236
    X197.685Y61.752
    X198.113Y62.321
    X198.464Y62.929
    X198.646Y63.363
    X198.787Y63.814
    X198.883Y64.275
    X199.658Y69.411
    X200.349Y74.561
    X200.956Y79.723
    X201.479Y84.895
    X201.918Y90.075
    X202.273Y95.261
    X202.543Y100.450
    X202.728Y105.641
    X202.706Y106.220
    X202.540Y107.141
    X202.284Y108.041
    X202.311Y108.149
    X202.391Y108.226
    X202.500Y108.250
    X203.256Y108.308
    X204.035Y108.281
    X204.825Y108.166
    X205.609Y107.957
    X206.372Y107.655
    X207.096Y107.266
    X207.768Y106.796
    X208.375Y106.257
    X208.907Y105.663
    X209.359Y105.027
    X209.728Y104.365
    X210.091Y103.531
    X210.367Y102.653
    X210.548Y101.745
    X210.630Y100.823
    X210.613Y99.903
    X210.500Y99.000
    X210.016Y95.836
    X209.602Y92.662
    X209.257Y89.480
    X208.983Y86.291
    X208.057Y73.504
    X207.695Y69.206
    X207.258Y64.915
    X207.352Y64.815
    X207.485Y64.787
    X208.122Y64.832
    X209.053Y65.036
    X209.997Y65.169
    X210.948Y65.232
    X215.122Y65.366
    X216.003Y65.453
    X216.875Y65.612
    X217.730Y65.840
    X218.369Y66.089
    X218.980Y66.422
    X219.549Y66.834
    X220.060Y67.315
    X220.502Y67.852
    X220.868Y68.432
    X221.233Y69.180
    X221.531Y69.960
    X221.757Y70.765
    X221.910Y71.583
    X222.103Y73.337
    X222.200Y76.056
    X222.238Y78.777
    X222.375Y80.500
    X222.830Y84.240
    X223.190Y87.991
    X223.455Y91.749
    X223.542Y93.998
    X223.557Y96.250
    X223.500Y98.500
    X223.124Y99.884
    X223.145Y100.026
    X223.250Y100.125
    X223.904Y100.338
    X224.601Y100.479
    X225.328Y100.537
    X226.071Y100.507
    X226.812Y100.383
    X227.536Y100.167
    X228.224Y99.864
    X228.862Y99.483
    X229.439Y99.036
    X229.944Y98.537
    X230.375Y98.000
    X230.486Y97.793
    X230.549Y97.567
    X230.572Y96.782
    X230.500Y96.000
    X230.455Y91.451
    X230.328Y86.902
    X230.118Y82.355
    X229.827Y77.812
    X229.454Y73.277
    X229.000Y68.750
    X228.974Y68.334
    X229.045Y67.909
    X229.213Y67.509
    X229.464Y67.166
    X229.775Y66.897
    X230.151Y66.697
    X230.571Y66.588
    X231.001Y66.578
    X231.409Y66.663
    X231.673Y66.797
    X231.906Y66.982
    X232.094Y67.210
    X232.602Y68.176
    X232.890Y68.569
    X233.260Y68.924
    X233.704Y69.214
    X234.204Y69.419
    X234.734Y69.526
    X235.265Y69.531
    X235.769Y69.441
    X236.227Y69.273
    X236.679Y69.032
    X237.103Y68.720
    X237.482Y68.342
    X237.803Y67.910
    X238.054Y67.437
    X238.230Y66.941
    X238.330Y66.438
    X238.360Y65.957
    X238.333Y65.474
    X238.250Y65.000
    X237.761Y62.736
    X236.271Y54.903
    X236.118Y53.944
    X236.031Y52.974
    X236.011Y52.000
    X236.057Y51.030
    X236.149Y50.436
    X236.325Y49.855
    X236.580Y49.304
    X236.905Y48.799
    X237.032Y48.696
    X237.190Y48.654
    X237.351Y48.681
    X237.487Y48.772
    X237.849Y49.104
    X238.164Y49.480
    X239.269Y51.028
    X240.306Y52.623
    X242.287Y55.959
    X244.599Y60.241
    X246.863Y64.548
    X248.084Y66.825
    X249.361Y69.072
    X250.692Y71.287
    X251.737Y72.906
    X252.847Y74.484
    X254.019Y76.017
    X255.250Y77.500
    X255.594Y77.796
    X255.985Y78.043
    X256.409Y78.230
    X256.855Y78.351
    X257.306Y78.405
    X257.956Y78.427
    X258.607Y78.363
    X259.241Y78.216
    X259.627Y78.082
    X259.991Y77.883
    X260.316Y77.626
    X260.590Y77.323
    X260.717Y77.077
    X260.790Y76.804
    X260.800Y76.521
    X260.750Y76.250
    X259.986Y73.552
    X259.173Y70.868
    X255.938Y60.699
    X255.187Y58.214
    X254.521Y55.702
    X253.940Y53.169
    X253.446Y50.618
    X253.039Y48.054
    X252.821Y46.055
    X252.686Y44.045
    X252.633Y42.028
    X252.663Y40.010
    X252.777Y37.996
    X252.972Y35.991
    X253.250Y34.000
    X254.867Y28.796
    X255.207Y27.866
    X255.585Y27.949
    X255.947Y28.086
    X256.521Y28.412
    X257.056Y28.802
    X257.542Y29.249
    X258.267Y30.036
    X258.949Y30.863
    X259.584Y31.727
    X260.169Y32.623
    X261.202Y34.340
    X262.180Y36.090
    X263.100Y37.871
    X263.962Y39.680
    X265.341Y42.750
    X266.647Y45.852
    X267.878Y48.985
    X269.578Y53.617
    X271.189Y58.283
    X272.709Y62.980
    X274.139Y67.706
    X275.477Y72.457
    X276.723Y77.232
    X277.736Y81.371
    X278.662Y85.532
    X279.500Y89.711
    X280.249Y93.907
    X280.636Y96.437
    X280.811Y97.925
    X281.054Y99.405
    X281.365Y100.870
    X283.127Y108.615
    X283.262Y109.738
    X283.464Y110.851
    X283.732Y111.950
    X284.096Y113.019
    X284.551Y114.056
    X285.091Y115.048
    X285.645Y115.899
    X286.258Y116.714
    X286.924Y117.487
    X287.639Y118.213
    X288.398Y118.887
    X289.317Y119.602
    X290.281Y120.262
    X291.286Y120.863
    X292.326Y121.400
    X293.395Y121.871
    X294.487Y122.275
    X295.625Y122.627
    X296.785Y122.913
    X297.962Y123.131
    X299.150Y123.279
    X300.342Y123.358
    X301.533Y123.368
    X302.647Y123.312
    X303.756Y123.182
    X304.852Y122.980
    X305.585Y122.768
    X306.303Y122.475
    X306.993Y122.102
    X307.643Y121.655
    X308.241Y121.139
    X308.777Y120.566
    X309.242Y119.945
    X309.633Y119.290
    X309.872Y118.740
    X310.052Y118.163
    X310.169Y117.568
    X310.220Y116.965
    X310.207Y116.366
    X309.971Y113.891
    X309.646Y111.408
    X309.228Y108.922
    X308.719Y106.437
    X308.116Y103.960
    X307.421Y101.494
    X306.632Y99.046
    X305.752Y96.620
    X304.780Y94.221
    X303.718Y91.855
    X302.567Y89.527
    X301.331Y87.242
    X300.010Y85.003
    X298.609Y82.817
    X297.130Y80.687
    X295.576Y78.617
    X293.952Y76.611
    X292.261Y74.673
    X290.507Y72.805
    X288.696Y71.011
    X286.830Y69.294
    X284.915Y67.654
    X282.956Y66.094
    X280.957Y64.616
    X280.638Y64.376
    X280.373Y64.066
    X280.181Y63.705
    X280.075Y63.321
    X280.108Y62.940
    X280.238Y62.571
    X280.454Y62.249
    X280.735Y61.997
    X281.079Y61.817
    X281.460Y61.729
    X281.842Y61.737
    X282.121Y61.829
    X282.365Y61.992
    X282.984Y62.827
    X283.656Y63.622
    X284.375Y64.372
    X285.141Y65.045
    X285.982Y65.671
    X286.893Y66.239
    X287.870Y66.738
    X288.904Y67.158
    X289.986Y67.490
    X291.104Y67.727
    X292.246Y67.863
    X293.398Y67.897
    X294.546Y67.826
    X295.676Y67.654
    X296.775Y67.385
    X297.832Y67.026
    X298.836Y66.584
    X299.778Y66.070
    X300.653Y65.494
    X301.457Y64.866
    X301.882Y64.502
    X302.267Y64.087
    X302.602Y63.630
    X302.882Y63.138
    X303.102Y62.623
    X303.209Y62.127
    X303.226Y61.620
    X303.081Y60.765
    X303.111Y60.742
    X305.881Y62.684
    X308.593Y64.708
    X311.245Y66.811
    X313.832Y68.991
    X313.979Y69.059
    X314.147Y69.065
    X314.298Y69.006
    X314.414Y68.894
    X314.479Y68.738
    X314.479Y68.577
    X314.379Y68.325
    X314.207Y68.116
    X310.721Y64.556
    X307.304Y60.931
    X303.957Y57.241
    X302.744Y56.127
    X302.555Y55.905
    X302.415Y55.645
    X302.332Y55.366
    X302.061Y53.685
    X301.698Y52.001
    X301.240Y50.322
    X300.688Y48.655
    X300.041Y47.008
    X299.301Y45.389
    X298.469Y43.806
    X297.548Y42.267
    X296.542Y40.779
    X295.455Y39.348
    X294.292Y37.982
    X293.059Y36.687
    X291.764Y35.466
    X290.411Y34.325
    X289.009Y33.268
    X287.565Y32.296
    X286.087Y31.411
    X284.582Y30.616
    X284.160Y30.434
    X283.707Y30.325
    X283.242Y30.294
    X282.785Y30.341
    X282.539Y30.405
    X282.306Y30.543
    X282.119Y30.746
    X282.001Y30.990
    X281.957Y31.241
    X282.026Y32.768
    X282.190Y34.305
    X282.449Y35.842
    X282.804Y37.370
    X283.256Y38.880
    X283.803Y40.364
    X284.442Y41.812
    X285.169Y43.216
    X285.979Y44.569
    X286.868Y45.862
    X287.828Y47.090
    X288.852Y48.247
    X289.933Y49.328
    X290.654Y49.949
    X291.326Y50.625
    X291.943Y51.351
    X292.486Y51.707
    X293.072Y51.988
    X293.777Y52.423
    X294.461Y52.938
    X295.109Y53.531
    X295.710Y54.200
    X296.251Y54.938
    X296.720Y55.738
    X297.108Y56.589
    X297.407Y57.477
    X297.612Y58.389
    X297.722Y59.310
    X297.738Y60.225
    X297.664Y61.121
    X297.506Y61.985
    X297.273Y62.808
    X296.974Y63.581
    X296.701Y64.097
    X296.348Y64.566
    X295.929Y64.972
    X295.530Y65.186
    X295.254Y65.242
    X294.969Y65.218
    X294.707Y65.116
    X293.296Y64.299
    X291.919Y63.393
    X290.584Y62.400
    X289.299Y61.323
    X288.072Y60.166
    X286.909Y58.934
    X285.818Y57.633
    X284.805Y56.268
    X283.874Y54.847
    X283.032Y53.378
    X282.280Y51.868
    X281.621Y50.326
    X281.057Y48.761
    X280.588Y47.181
    X280.214Y45.594
    X279.971Y44.233
    X279.774Y42.863
    X279.622Y41.489
    X279.467Y41.089
    X279.238Y40.704
    X278.937Y40.353
    X278.573Y40.057
    X278.163Y39.829
    X277.725Y39.680
    X277.282Y39.611
    X276.854Y39.615
    X276.375Y39.684
    X275.897Y39.836
    X275.442Y40.071
    X275.030Y40.382
    X274.680Y40.756
    X274.404Y41.174
    X274.207Y41.616
    X273.802Y42.802
    X273.489Y44.022
    X273.274Y45.266
    X273.158Y46.520
    X273.140Y47.773
    X273.226Y49.105
    X273.383Y50.430
    X273.370Y50.824
    X273.273Y51.211
    X273.098Y51.564
    X272.935Y51.743
    X272.715Y51.841
    X272.473Y51.844
    X272.250Y51.750
    G0Z5.000
    G0X0.000Y0.000Z10.000
    G0Z10.000
    G0X0Y0
    M30
    Did you give the machine the proper shakedown with the Hello World test? docs:blackbox:hello-world [OpenBuilds Documentation]
    Did you remember to SETZERO to tell the machine where the stock is?
    Did you check Calibration?
    The header of the GCODE needs a G20/G21 to tell it what units the GCODE are in and also ideally a G90/G91 to tell it the moves are absolute or incremental (looks like absolute coordinates to me)
    See G Codes and G Codes respectively
    The M6 line got to go too, Grbl doesn't support Toolchanges
  9. Cruiser
    Cruiser New
    No I didnt,
    I learnt on a machine from a friend, what we did was create the piece in artcam, set the origin on the bottom left then made sure the piece fits in the machine bed properly.
    We then set 0 on the bottom left of the workpiece and off it went.
    I thought this machine would be the same but when I set it up it went totally in a different direction.
    I then learnt about the homing, so ive bought the switches and set three up, one on each XYZ.....I may need two on each axis apart from the Z?
    Im gonna have to learn a lot or be spoon fed a way as the more info I get the more confusing and impossible it seems
    I have grey areas after grey areas at the moment
    Carveco looks great but I just cant afford any extra at the moment
    I really appreciate all your answers!
  10. Cruiser
    Cruiser New
    also as I have to use a custom machine in the software, Im getting passed that hurdle too at the moment as the OX isnt listed,
    Ive read its an older machine and there are too many variables with it, half way there with setting the machine up.
  11. Peter Van Der Walt
    You only need one per axis for homing.
    You can then choose whether Homing+Soft limits will be good enough for you (it is if the machine is built well) or if you want to add more switches to tame a runaway machine with Hard Limits too)
    Plenty of free options: docs:software:overview [OpenBuilds Documentation] - may need you to learn a new CAM but if money is an issue, free is worth the time
    Make sure its built correctly, by testing with a known working CAM like OpenBuildsCAM and the Hello World example first. Easier to try experimental CAM stuff if you know for sure the machine is set up correctly
    As for learning curve:
    Home · gnea/grbl Wiki
    and
    start [OpenBuilds Documentation]
    should get you up to speed
    Cruiser likes this.
  12. Cruiser
    Cruiser New
    yes will do,
    going to look at the new software, I have no problem learning a new one as time I have.
    Ill run the Hello World as soon as its ready and set to go, waiting on a drag chain and managing wires and table at the moment.
    Fusion360?
  13. Peter Van Der Walt
    Free for non commercial use, we have a post processor in the link above for it
  14. Cruiser
    Cruiser New
    Hi Again....does this look better?
    I put this into openbuilds control and a few of the items were highlighted in red.
    G90 M3 G0 G1 G1 in the first few lines
    The last three G0 and M4
    Plus a few G1 throughout.....
    Could that be the spindle stepping down to cut the material out. If so, step overs would also be in red?
    This cnc lark is so flipping cool! love it
    Code:
    G90
    G49
    Z2
    M3 S15000
    G0 X-446.270 Y135.000 Z5.000
    G1   Z-1.250 F720
    G1 X-446.228 Y139.742  F2520
    X-446.091 Y144.491
    X-445.861 Y149.242
    X-445.537 Y153.995
    X-445.118 Y158.745
    X-444.605 Y163.490
    X-443.998 Y168.227
    X-443.297 Y172.954
    X-442.501 Y177.667
    X-441.613 Y182.364
    X-440.632 Y187.042
    X-439.558 Y191.698
    X-438.393 Y196.329
    X-437.138 Y200.934
    X-435.793 Y205.509
    X-434.359 Y210.051
    X-432.838 Y214.559
    X-431.230 Y219.029
    X-429.538 Y223.459
    X-427.728 Y227.911
    X-425.825 Y232.335
    X-423.831 Y236.730
    X-421.746 Y241.091
    X-419.570 Y245.417
    X-417.304 Y249.705
    X-414.951 Y253.951
    X-412.509 Y258.154
    X-409.982 Y262.310
    X-407.370 Y266.416
    X-404.675 Y270.471
    X-401.898 Y274.472
    X-399.041 Y278.416
    X-396.106 Y282.300
    X-393.095 Y286.124
    X-390.009 Y289.883
    X-386.850 Y293.577
    X-383.622 Y297.203
    X-380.325 Y300.759
    X-376.962 Y304.244
    X-373.536 Y307.654
    X-370.049 Y310.990
    X-366.503 Y314.249
    X-362.900 Y317.430
    X-359.245 Y320.537
    X-355.520 Y323.578
    X-351.728 Y326.549
    X-347.871 Y329.449
    X-343.951 Y332.274
    X-339.969 Y335.024
    X-335.928 Y337.697
    X-331.830 Y340.290
    X-327.678 Y342.801
    X-323.474 Y345.230
    X-319.221 Y347.574
    X-314.920 Y349.832
    X-310.576 Y352.002
    X-306.190 Y354.084
    X-301.765 Y356.076
    X-297.304 Y357.976
    X-292.810 Y359.785
    X-288.285 Y361.502
    X-283.733 Y363.125
    X-279.156 Y364.653
    X-274.557 Y366.088
    X-269.939 Y367.427
    X-265.306 Y368.672
    X-260.659 Y369.816
    X-255.985 Y370.869
    X-251.287 Y371.830
    X-246.567 Y372.698
    X-241.827 Y373.473
    X-237.072 Y374.155
    X-232.303 Y374.742
    X-227.523 Y375.234
    X-222.735 Y375.631
    X-217.943 Y375.934
    X-213.148 Y376.140
    X-208.353 Y376.252
    X-203.562 Y376.269
    X-198.778 Y376.192
    X-194.115 Y376.032
    X-189.450 Y375.782
    X-184.784 Y375.441
    X-180.120 Y375.008
    X-175.461 Y374.484
    X-170.810 Y373.869
    X-166.168 Y373.163
    X-161.540 Y372.366
    X-156.927 Y371.479
    X-152.333 Y370.502
    X-147.759 Y369.435
    X-143.209 Y368.280
    X-138.685 Y367.037
    X-134.189 Y365.707
    X-129.724 Y364.291
    X-125.293 Y362.790
    X-120.898 Y361.205
    X-116.541 Y359.538
    X-112.089 Y357.728
    X-107.665 Y355.825
    X-103.270 Y353.831
    X-98.909 Y351.746
    X-94.583 Y349.570
    X-90.295 Y347.304
    X-86.049 Y344.951
    X-81.846 Y342.509
    X-77.690 Y339.982
    X-73.584 Y337.370
    X-69.529 Y334.675
    X-65.528 Y331.898
    X-61.584 Y329.041
    X-57.700 Y326.106
    X-53.876 Y323.095
    X-50.117 Y320.009
    X-46.423 Y316.850
    X-42.797 Y313.622
    X-39.241 Y310.325
    X-35.756 Y306.962
    X-32.346 Y303.536
    X-29.010 Y300.049
    X-25.751 Y296.503
    X-22.570 Y292.900
    X-19.463 Y289.245
    X-16.422 Y285.520
    X-13.451 Y281.728
    X-10.551 Y277.871
    X-7.726 Y273.951
    X-4.976 Y269.969
    X-2.303 Y265.928
    X0.290 Y261.830
    X2.801 Y257.678
    X5.230 Y253.474
    X7.574 Y249.221
    X9.832 Y244.920
    X12.002 Y240.576
    X14.084 Y236.190
    X16.076 Y231.765
    X17.976 Y227.304
    X19.785 Y222.810
    X21.502 Y218.285
    X23.125 Y213.733
    X24.653 Y209.156
    X26.088 Y204.557
    X27.427 Y199.939
    X28.672 Y195.306
    X29.816 Y190.659
    X30.869 Y185.985
    X31.830 Y181.287
    X32.698 Y176.567
    X33.473 Y171.827
    X34.155 Y167.072
    X34.742 Y162.303
    X35.234 Y157.523
    X35.631 Y152.735
    X35.934 Y147.943
    X36.140 Y143.148
    X36.252 Y138.353
    X36.269 Y133.562
    X36.192 Y128.778
    X36.032 Y124.115
    X35.782 Y119.450
    X35.441 Y114.784
    X35.008 Y110.120
    X34.484 Y105.461
    X33.869 Y100.810
    X33.163 Y96.168
    X32.366 Y91.540
    X31.479 Y86.927
    X30.502 Y82.333
    X29.435 Y77.759
    X28.280 Y73.209
    X27.037 Y68.685
    X25.707 Y64.189
    X24.291 Y59.724
    X22.790 Y55.293
    X21.205 Y50.898
    X19.538 Y46.541
    X17.728 Y42.089
    X15.825 Y37.665
    X13.831 Y33.270
    X11.746 Y28.909
    X9.570 Y24.583
    X7.304 Y20.295
    X4.951 Y16.049
    X2.509 Y11.846
    X-0.018 Y7.690
    X-2.630 Y3.584
    X-5.325 Y-0.471
    X-8.102 Y-4.472
    X-10.959 Y-8.416
    X-13.894 Y-12.300
    X-16.905 Y-16.124
    X-19.991 Y-19.883
    X-23.150 Y-23.577
    X-26.378 Y-27.203
    X-29.675 Y-30.759
    X-33.038 Y-34.244
    X-36.464 Y-37.654
    X-39.951 Y-40.990
    X-43.497 Y-44.249
    X-47.100 Y-47.430
    X-50.755 Y-50.537
    X-54.480 Y-53.578
    X-58.272 Y-56.549
    X-62.129 Y-59.449
    X-66.049 Y-62.274
    X-70.031 Y-65.024
    X-74.072 Y-67.697
    X-78.170 Y-70.290
    X-82.322 Y-72.801
    X-86.526 Y-75.230
    X-90.779 Y-77.574
    X-95.080 Y-79.832
    X-99.424 Y-82.002
    X-103.810 Y-84.084
    X-108.235 Y-86.076
    X-112.696 Y-87.976
    X-117.190 Y-89.785
    X-121.715 Y-91.502
    X-126.267 Y-93.125
    X-130.844 Y-94.653
    X-135.443 Y-96.088
    X-140.061 Y-97.427
    X-144.694 Y-98.672
    X-149.341 Y-99.816
    X-154.015 Y-100.869
    X-158.713 Y-101.830
    X-163.433 Y-102.698
    X-168.173 Y-103.473
    X-172.928 Y-104.155
    X-177.697 Y-104.742
    X-182.477 Y-105.234
    X-187.265 Y-105.631
    X-192.057 Y-105.934
    X-196.852 Y-106.140
    X-201.647 Y-106.252
    X-206.438 Y-106.269
    X-211.222 Y-106.192
    X-216.104 Y-106.022
    X-220.988 Y-105.753
    X-225.872 Y-105.385
    X-230.753 Y-104.916
    X-235.627 Y-104.348
    X-240.492 Y-103.680
    X-245.344 Y-102.912
    X-250.180 Y-102.046
    X-254.997 Y-101.081
    X-259.793 Y-100.017
    X-264.564 Y-98.857
    X-269.308 Y-97.601
    X-274.021 Y-96.249
    X-278.700 Y-94.803
    X-283.344 Y-93.264
    X-287.948 Y-91.633
    X-292.413 Y-89.945
    X-296.853 Y-88.165
    X-301.265 Y-86.294
    X-305.646 Y-84.332
    X-309.994 Y-82.280
    X-314.306 Y-80.140
    X-318.579 Y-77.911
    X-322.810 Y-75.596
    X-326.998 Y-73.194
    X-331.138 Y-70.709
    X-335.229 Y-68.140
    X-339.268 Y-65.490
    X-343.254 Y-62.759
    X-347.182 Y-59.950
    X-351.052 Y-57.065
    X-354.860 Y-54.105
    X-358.606 Y-51.073
    X-362.286 Y-47.969
    X-365.899 Y-44.798
    X-369.442 Y-41.559
    X-372.915 Y-38.257
    X-376.316 Y-34.892
    X-379.642 Y-31.469
    X-382.911 Y-27.976
    X-386.117 Y-24.411
    X-389.257 Y-20.776
    X-392.329 Y-17.073
    X-395.332 Y-13.304
    X-398.262 Y-9.470
    X-401.118 Y-5.574
    X-403.897 Y-1.618
    X-406.599 Y2.395
    X-409.221 Y6.464
    X-411.762 Y10.587
    X-414.219 Y14.759
    X-416.592 Y18.980
    X-418.879 Y23.247
    X-421.079 Y27.556
    X-423.190 Y31.906
    X-425.212 Y36.292
    X-427.144 Y40.714
    X-428.984 Y45.168
    X-430.732 Y49.650
    X-432.388 Y54.160
    X-433.951 Y58.692
    X-435.420 Y63.245
    X-436.809 Y67.883
    X-438.107 Y72.554
    X-439.311 Y77.255
    X-440.422 Y81.984
    X-441.438 Y86.738
    X-442.358 Y91.514
    X-443.182 Y96.309
    X-443.910 Y101.120
    X-444.540 Y105.944
    X-445.073 Y110.778
    X-445.508 Y115.620
    X-445.845 Y120.466
    X-446.084 Y125.313
    X-446.226 Y130.159
    X-446.270 Y135.000
    G1   Z-2.500 F720
    X-446.091 Y144.491
    X-445.861 Y149.242
    X-445.537 Y153.995
    X-445.118 Y158.745
    X-444.605 Y163.490
    X-443.998 Y168.227
    X-443.297 Y172.954
    X-442.501 Y177.667
    X-441.613 Y182.364
    X-440.632 Y187.042
    X-439.558 Y191.698
    X-438.393 Y196.329
    X-437.138 Y200.934
    X-435.793 Y205.509
    X-434.359 Y210.051
    X-432.838 Y214.559
    X-431.230 Y219.029
    X-429.538 Y223.459
    X-427.728 Y227.911
    X-425.825 Y232.335
    X-423.831 Y236.730
    X-421.746 Y241.091
    X-419.570 Y245.417
    X-417.304 Y249.705
    X-414.951 Y253.951
    X-412.509 Y258.154
    X-409.982 Y262.310
    X-407.370 Y266.416
    X-404.675 Y270.471
    X-401.898 Y274.472
    X-399.041 Y278.416
    X-396.106 Y282.300
    X-393.095 Y286.124
    X-390.009 Y289.883
    X-386.850 Y293.577
    X-383.622 Y297.203
    X-380.325 Y300.759
    X-376.962 Y304.244
    X-373.536 Y307.654
    X-370.049 Y310.990
    X-366.503 Y314.249
    X-362.900 Y317.430
    X-359.245 Y320.537
    X-355.520 Y323.578
    X-351.728 Y326.549
    X-347.871 Y329.449
    X-343.951 Y332.274
    X-339.969 Y335.024
    X-335.928 Y337.697
    X-331.830 Y340.290
    X-327.678 Y342.801
    X-323.474 Y345.230
    X-319.221 Y347.574
    X-314.920 Y349.832
    X-310.576 Y352.002
    X-306.190 Y354.084
    X-301.765 Y356.076
    X-297.304 Y357.976
    X-292.810 Y359.785
    X-288.285 Y361.502
    X-283.733 Y363.125
    X-279.156 Y364.653
    X-274.557 Y366.088
    X-269.939 Y367.427
    X-265.306 Y368.672
    X-260.659 Y369.816
    X-255.985 Y370.869
    X-251.287 Y371.830
    X-246.567 Y372.698
    X-241.827 Y373.473
    X-237.072 Y374.155
    X-232.303 Y374.742
    X-227.523 Y375.234
    X-222.735 Y375.631
    X-217.943 Y375.934
    X-213.148 Y376.140
    X-208.353 Y376.252
    X-203.562 Y376.269
    X-198.778 Y376.192
    X-194.115 Y376.032
    X-189.450 Y375.782
    X-184.784 Y375.441
    X-180.120 Y375.008
    X-175.461 Y374.484
    X-170.810 Y373.869
    X-166.168 Y373.163
    X-161.540 Y372.366
    X-156.927 Y371.479
    X-152.333 Y370.502
    X-147.759 Y369.435
    X-143.209 Y368.280
    X-138.685 Y367.037
    X-134.189 Y365.707
    X-129.724 Y364.291
    X-125.293 Y362.790
    X-120.898 Y361.205
    X-116.541 Y359.538
    X-112.089 Y357.728
    X-107.665 Y355.825
    X-103.270 Y353.831
    X-98.909 Y351.746
    X-94.583 Y349.570
    X-90.295 Y347.304
    X-86.049 Y344.951
    X-81.846 Y342.509
    X-77.690 Y339.982
    X-73.584 Y337.370
    X-69.529 Y334.675
    X-65.528 Y331.898
    X-61.584 Y329.041
    X-57.700 Y326.106
    X-53.876 Y323.095
    X-50.117 Y320.009
    X-46.423 Y316.850
    X-42.797 Y313.622
    X-39.241 Y310.325
    X-35.756 Y306.962
    X-32.346 Y303.536
    X-29.010 Y300.049
    X-25.751 Y296.503
    X-22.570 Y292.900
    X-19.463 Y289.245
    X-16.422 Y285.520
    X-13.451 Y281.728
    X-10.551 Y277.871
    X-7.726 Y273.951
    X-4.976 Y269.969
    X-2.303 Y265.928
    X0.290 Y261.830
    X2.801 Y257.678
    X5.230 Y253.474
    X7.574 Y249.221
    X9.832 Y244.920
    X12.002 Y240.576
    X14.084 Y236.190
    X16.076 Y231.765
    X17.976 Y227.304
    X19.785 Y222.810
    X21.502 Y218.285
    X23.125 Y213.733
    X24.653 Y209.156
    X26.088 Y204.557
    X27.427 Y199.939
    X28.672 Y195.306
    X29.816 Y190.659
    X30.869 Y185.985
    X31.830 Y181.287
    X32.698 Y176.567
    X33.473 Y171.827
    X34.155 Y167.072
    X34.742 Y162.303
    X35.234 Y157.523
    X35.631 Y152.735
    X35.934 Y147.943
    X36.140 Y143.148
    X36.252 Y138.353
    X36.269 Y133.562
    X36.192 Y128.778
    X36.032 Y124.115
    X35.782 Y119.450
    X35.441 Y114.784
    X35.008 Y110.120
    X34.484 Y105.461
    X33.869 Y100.810
    X33.163 Y96.168
    X32.366 Y91.540
    X31.479 Y86.927
    X30.502 Y82.333
    X29.435 Y77.759
    X28.280 Y73.209
    X27.037 Y68.685
    X25.707 Y64.189
    X24.291 Y59.724
    X22.790 Y55.293
    X21.205 Y50.898
    X19.538 Y46.541
    X17.728 Y42.089
    X15.825 Y37.665
    X13.831 Y33.270
    X11.746 Y28.909
    X9.570 Y24.583
    X7.304 Y20.295
    X4.951 Y16.049
    X2.509 Y11.846
    X-0.018 Y7.690
    X-2.630 Y3.584
    X-5.325 Y-0.471
    X-8.102 Y-4.472
    X-10.959 Y-8.416
    X-13.894 Y-12.300
    X-16.905 Y-16.124
    X-19.991 Y-19.883
    X-23.150 Y-23.577
    X-26.378 Y-27.203
    X-29.675 Y-30.759
    X-33.038 Y-34.244
    X-36.464 Y-37.654
    X-39.951 Y-40.990
    X-43.497 Y-44.249
    X-47.100 Y-47.430
    X-50.755 Y-50.537
    X-54.480 Y-53.578
    X-58.272 Y-56.549
    X-62.129 Y-59.449
    X-66.049 Y-62.274
    X-70.031 Y-65.024
    X-74.072 Y-67.697
    X-78.170 Y-70.290
    X-82.322 Y-72.801
    X-86.526 Y-75.230
    X-90.779 Y-77.574
    X-95.080 Y-79.832
    X-99.424 Y-82.002
    X-103.810 Y-84.084
    X-108.235 Y-86.076
    X-112.696 Y-87.976
    X-117.190 Y-89.785
    X-121.715 Y-91.502
    X-126.267 Y-93.125
    X-130.844 Y-94.653
    X-135.443 Y-96.088
    X-140.061 Y-97.427
    X-144.694 Y-98.672
    X-149.341 Y-99.816
    X-154.015 Y-100.869
    X-158.713 Y-101.830
    X-163.433 Y-102.698
    X-168.173 Y-103.473
    X-172.928 Y-104.155
    X-177.697 Y-104.742
    X-182.477 Y-105.234
    X-187.265 Y-105.631
    X-192.057 Y-105.934
    X-196.852 Y-106.140
    X-201.647 Y-106.252
    X-206.438 Y-106.269
    X-211.222 Y-106.192
    X-216.104 Y-106.022
    X-220.988 Y-105.753
    X-225.872 Y-105.385
    X-230.753 Y-104.916
    X-235.627 Y-104.348
    X-240.492 Y-103.680
    X-245.344 Y-102.912
    X-250.180 Y-102.046
    X-254.997 Y-101.081
    X-259.793 Y-100.017
    X-264.564 Y-98.857
    X-269.308 Y-97.601
    X-274.021 Y-96.249
    X-278.700 Y-94.803
    X-283.344 Y-93.264
    X-287.948 Y-91.633
    X-292.413 Y-89.945
    X-296.853 Y-88.165
    X-301.265 Y-86.294
    X-305.646 Y-84.332
    X-309.994 Y-82.280
    X-314.306 Y-80.140
    X-318.579 Y-77.911
    X-322.810 Y-75.596
    X-326.998 Y-73.194
    X-331.138 Y-70.709
    X-335.229 Y-68.140
    X-339.268 Y-65.490
    X-343.254 Y-62.759
    X-347.182 Y-59.950
    X-351.052 Y-57.065
    X-354.860 Y-54.105
    X-358.606 Y-51.073
    X-362.286 Y-47.969
    X-365.899 Y-44.798
    X-369.442 Y-41.559
    X-372.915 Y-38.257
    X-376.316 Y-34.892
    X-379.642 Y-31.469
    X-382.911 Y-27.976
    X-386.117 Y-24.411
    X-389.257 Y-20.776
    X-392.329 Y-17.073
    X-395.332 Y-13.304
    X-398.262 Y-9.470
    X-401.118 Y-5.574
    X-403.897 Y-1.618
    X-406.599 Y2.395
    X-409.221 Y6.464
    X-411.762 Y10.587
    X-414.219 Y14.759
    X-416.592 Y18.980
    X-418.879 Y23.247
    X-421.079 Y27.556
    X-423.190 Y31.906
    X-425.212 Y36.292
    X-427.144 Y40.714
    X-428.984 Y45.168
    X-430.732 Y49.650
    X-432.388 Y54.160
    X-433.951 Y58.692
    X-435.420 Y63.245
    X-436.809 Y67.883
    X-438.107 Y72.554
    X-439.311 Y77.255
    X-440.422 Y81.984
    X-441.438 Y86.738
    X-442.358 Y91.514
    X-443.182 Y96.309
    X-443.910 Y101.120
    X-444.540 Y105.944
    X-445.073 Y110.778
    X-445.508 Y115.620
    X-445.845 Y120.466
    X-446.084 Y125.313
    X-446.226 Y130.159
    X-446.270 Y135.000
    G1   Z-3.750 F720
    X-446.091 Y144.491
    X-445.861 Y149.242
    X-445.537 Y153.995
    X-445.118 Y158.745
    X-444.605 Y163.490
    X-443.998 Y168.227
    X-443.297 Y172.954
    X-442.501 Y177.667
    X-441.613 Y182.364
    X-440.632 Y187.042
    X-439.558 Y191.698
    X-438.393 Y196.329
    X-437.138 Y200.934
    X-435.793 Y205.509
    X-434.359 Y210.051
    X-432.838 Y214.559
    X-431.230 Y219.029
    X-429.538 Y223.459
    X-427.728 Y227.911
    X-425.825 Y232.335
    X-423.831 Y236.730
    X-421.746 Y241.091
    X-419.570 Y245.417
    X-417.304 Y249.705
    X-414.951 Y253.951
    X-412.509 Y258.154
    X-409.982 Y262.310
    X-407.370 Y266.416
    X-404.675 Y270.471
    X-401.898 Y274.472
    X-399.041 Y278.416
    X-396.106 Y282.300
    X-393.095 Y286.124
    X-390.009 Y289.883
    X-386.850 Y293.577
    X-383.622 Y297.203
    X-380.325 Y300.759
    X-376.962 Y304.244
    X-373.536 Y307.654
    X-370.049 Y310.990
    X-366.503 Y314.249
    X-362.900 Y317.430
    X-359.245 Y320.537
    X-355.520 Y323.578
    X-351.728 Y326.549
    X-347.871 Y329.449
    X-343.951 Y332.274
    X-339.969 Y335.024
    X-335.928 Y337.697
    X-331.830 Y340.290
    X-327.678 Y342.801
    X-323.474 Y345.230
    X-319.221 Y347.574
    X-314.920 Y349.832
    X-310.576 Y352.002
    X-306.190 Y354.084
    X-301.765 Y356.076
    X-297.304 Y357.976
    X-292.810 Y359.785
    X-288.285 Y361.502
    X-283.733 Y363.125
    X-279.156 Y364.653
    X-274.557 Y366.088
    X-269.939 Y367.427
    X-265.306 Y368.672
    X-260.659 Y369.816
    X-255.985 Y370.869
    X-251.287 Y371.830
    X-246.567 Y372.698
    X-241.827 Y373.473
    X-237.072 Y374.155
    X-232.303 Y374.742
    X-227.523 Y375.234
    X-222.735 Y375.631
    X-217.943 Y375.934
    X-213.148 Y376.140
    X-208.353 Y376.252
    X-203.562 Y376.269
    X-198.778 Y376.192
    X-194.115 Y376.032
    X-189.450 Y375.782
    X-184.784 Y375.441
    X-180.120 Y375.008
    X-175.461 Y374.484
    X-170.810 Y373.869
    X-166.168 Y373.163
    X-161.540 Y372.366
    X-156.927 Y371.479
    X-152.333 Y370.502
    X-147.759 Y369.435
    X-143.209 Y368.280
    X-138.685 Y367.037
    X-134.189 Y365.707
    X-129.724 Y364.291
    X-125.293 Y362.790
    X-120.898 Y361.205
    X-116.541 Y359.538
    X-112.089 Y357.728
    X-107.665 Y355.825
    X-103.270 Y353.831
    X-98.909 Y351.746
    X-94.583 Y349.570
    X-90.295 Y347.304
    X-86.049 Y344.951
    X-81.846 Y342.509
    X-77.690 Y339.982
    X-73.584 Y337.370
    X-69.529 Y334.675
    X-65.528 Y331.898
    X-61.584 Y329.041
    X-57.700 Y326.106
    X-53.876 Y323.095
    X-50.117 Y320.009
    X-46.423 Y316.850
    X-42.797 Y313.622
    X-39.241 Y310.325
    X-35.756 Y306.962
    X-32.346 Y303.536
    X-29.010 Y300.049
    X-25.751 Y296.503
    X-22.570 Y292.900
    X-19.463 Y289.245
    X-16.422 Y285.520
    X-13.451 Y281.728
    X-10.551 Y277.871
    X-7.726 Y273.951
    X-4.976 Y269.969
    X-2.303 Y265.928
    X0.290 Y261.830
    X2.801 Y257.678
    X5.230 Y253.474
    X7.574 Y249.221
    X9.832 Y244.920
    X12.002 Y240.576
    X14.084 Y236.190
    X16.076 Y231.765
    X17.976 Y227.304
    X19.785 Y222.810
    X21.502 Y218.285
    X23.125 Y213.733
    X24.653 Y209.156
    X26.088 Y204.557
    X27.427 Y199.939
    X28.672 Y195.306
    X29.816 Y190.659
    X30.869 Y185.985
    X31.830 Y181.287
    X32.698 Y176.567
    X33.473 Y171.827
    X34.155 Y167.072
    X34.742 Y162.303
    X35.234 Y157.523
    X35.631 Y152.735
    X35.934 Y147.943
    X36.140 Y143.148
    X36.252 Y138.353
    X36.269 Y133.562
    X36.192 Y128.778
    X36.032 Y124.115
    X35.782 Y119.450
    X35.441 Y114.784
    X35.008 Y110.120
    X34.484 Y105.461
    X33.869 Y100.810
    X33.163 Y96.168
    X32.366 Y91.540
    X31.479 Y86.927
    X30.502 Y82.333
    X29.435 Y77.759
    X28.280 Y73.209
    X27.037 Y68.685
    X25.707 Y64.189
    X24.291 Y59.724
    X22.790 Y55.293
    X21.205 Y50.898
    X19.538 Y46.541
    X17.728 Y42.089
    X15.825 Y37.665
    X13.831 Y33.270
    X11.746 Y28.909
    X9.570 Y24.583
    X7.304 Y20.295
    X4.951 Y16.049
    X2.509 Y11.846
    X-0.018 Y7.690
    X-2.630 Y3.584
    X-5.325 Y-0.471
    X-8.102 Y-4.472
    X-10.959 Y-8.416
    X-13.894 Y-12.300
    X-16.905 Y-16.124
    X-19.991 Y-19.883
    X-23.150 Y-23.577
    X-26.378 Y-27.203
    X-29.675 Y-30.759
    X-33.038 Y-34.244
    X-36.464 Y-37.654
    X-39.951 Y-40.990
    X-43.497 Y-44.249
    X-47.100 Y-47.430
    X-50.755 Y-50.537
    X-54.480 Y-53.578
    X-58.272 Y-56.549
    X-62.129 Y-59.449
    X-66.049 Y-62.274
    X-70.031 Y-65.024
    X-74.072 Y-67.697
    X-78.170 Y-70.290
    X-82.322 Y-72.801
    X-86.526 Y-75.230
    X-90.779 Y-77.574
    X-95.080 Y-79.832
    X-99.424 Y-82.002
    X-103.810 Y-84.084
    X-108.235 Y-86.076
    X-112.696 Y-87.976
    X-117.190 Y-89.785
    X-121.715 Y-91.502
    X-126.267 Y-93.125
    X-130.844 Y-94.653
    X-135.443 Y-96.088
    X-140.061 Y-97.427
    X-144.694 Y-98.672
    X-149.341 Y-99.816
    X-154.015 Y-100.869
    X-158.713 Y-101.830
    X-163.433 Y-102.698
    X-168.173 Y-103.473
    X-172.928 Y-104.155
    X-177.697 Y-104.742
    X-182.477 Y-105.234
    X-187.265 Y-105.631
    X-192.057 Y-105.934
    X-196.852 Y-106.140
    X-201.647 Y-106.252
    X-206.438 Y-106.269
    X-211.222 Y-106.192
    X-216.104 Y-106.022
    X-220.988 Y-105.753
    X-225.872 Y-105.385
    X-230.753 Y-104.916
    X-235.627 Y-104.348
    X-240.492 Y-103.680
    X-245.344 Y-102.912
    X-250.180 Y-102.046
    X-254.997 Y-101.081
    X-259.793 Y-100.017
    X-264.564 Y-98.857
    X-269.308 Y-97.601
    X-274.021 Y-96.249
    X-278.700 Y-94.803
    X-283.344 Y-93.264
    X-287.948 Y-91.633
    X-292.413 Y-89.945
    X-296.853 Y-88.165
    X-301.265 Y-86.294
    X-305.646 Y-84.332
    X-309.994 Y-82.280
    X-314.306 Y-80.140
    X-318.579 Y-77.911
    X-322.810 Y-75.596
    X-326.998 Y-73.194
    X-331.138 Y-70.709
    X-335.229 Y-68.140
    X-339.268 Y-65.490
    X-343.254 Y-62.759
    X-347.182 Y-59.950
    X-351.052 Y-57.065
    X-354.860 Y-54.105
    X-358.606 Y-51.073
    X-362.286 Y-47.969
    X-365.899 Y-44.798
    X-369.442 Y-41.559
    X-372.915 Y-38.257
    X-376.316 Y-34.892
    X-379.642 Y-31.469
    X-382.911 Y-27.976
    X-386.117 Y-24.411
    X-389.257 Y-20.776
    X-392.329 Y-17.073
    X-395.332 Y-13.304
    X-398.262 Y-9.470
    X-401.118 Y-5.574
    X-403.897 Y-1.618
    X-406.599 Y2.395
    X-409.221 Y6.464
    X-411.762 Y10.587
    X-414.219 Y14.759
    X-416.592 Y18.980
    X-418.879 Y23.247
    X-421.079 Y27.556
    X-423.190 Y31.906
    X-425.212 Y36.292
    X-427.144 Y40.714
    X-428.984 Y45.168
    X-430.732 Y49.650
    X-432.388 Y54.160
    X-433.951 Y58.692
    X-435.420 Y63.245
    X-436.809 Y67.883
    X-438.107 Y72.554
    X-439.311 Y77.255
    X-440.422 Y81.984
    X-441.438 Y86.738
    X-442.358 Y91.514
    X-443.182 Y96.309
    X-443.910 Y101.120
    X-444.540 Y105.944
    X-445.073 Y110.778
    X-445.508 Y115.620
    X-445.845 Y120.466
    X-446.084 Y125.313
    X-446.226 Y130.159
    X-446.270 Y135.000
    G1   Z-5.000 F720
    X-446.091 Y144.491
    X-445.861 Y149.242
    X-445.537 Y153.995
    X-445.118 Y158.745
    X-444.605 Y163.490
    X-443.998 Y168.227
    X-443.297 Y172.954
    X-442.501 Y177.667
    X-441.613 Y182.364
    X-440.632 Y187.042
    X-439.558 Y191.698
    X-438.393 Y196.329
    X-437.138 Y200.934
    X-435.793 Y205.509
    X-434.359 Y210.051
    X-432.838 Y214.559
    X-431.230 Y219.029
    X-429.538 Y223.459
    X-427.728 Y227.911
    X-425.825 Y232.335
    X-423.831 Y236.730
    X-421.746 Y241.091
    X-419.570 Y245.417
    X-417.304 Y249.705
    X-414.951 Y253.951
    X-412.509 Y258.154
    X-409.982 Y262.310
    X-407.370 Y266.416
    X-404.675 Y270.471
    X-401.898 Y274.472
    X-399.041 Y278.416
    X-396.106 Y282.300
    X-393.095 Y286.124
    X-390.009 Y289.883
    X-386.850 Y293.577
    X-383.622 Y297.203
    X-380.325 Y300.759
    X-376.962 Y304.244
    X-373.536 Y307.654
    X-370.049 Y310.990
    X-366.503 Y314.249
    X-362.900 Y317.430
    X-359.245 Y320.537
    X-355.520 Y323.578
    X-351.728 Y326.549
    X-347.871 Y329.449
    X-343.951 Y332.274
    X-339.969 Y335.024
    X-335.928 Y337.697
    X-331.830 Y340.290
    X-327.678 Y342.801
    X-323.474 Y345.230
    X-319.221 Y347.574
    X-314.920 Y349.832
    X-310.576 Y352.002
    X-306.190 Y354.084
    X-301.765 Y356.076
    X-297.304 Y357.976
    X-292.810 Y359.785
    X-288.285 Y361.502
    X-283.733 Y363.125
    X-279.156 Y364.653
    X-274.557 Y366.088
    X-269.939 Y367.427
    X-265.306 Y368.672
    X-260.659 Y369.816
    X-255.985 Y370.869
    X-251.287 Y371.830
    X-246.567 Y372.698
    X-241.827 Y373.473
    X-237.072 Y374.155
    X-232.303 Y374.742
    X-227.523 Y375.234
    X-222.735 Y375.631
    X-217.943 Y375.934
    X-213.148 Y376.140
    X-208.353 Y376.252
    X-203.562 Y376.269
    X-198.778 Y376.192
    X-194.115 Y376.032
    X-189.450 Y375.782
    X-184.784 Y375.441
    X-180.120 Y375.008
    X-175.461 Y374.484
    X-170.810 Y373.869
    X-166.168 Y373.163
    X-161.540 Y372.366
    X-156.927 Y371.479
    X-152.333 Y370.502
    X-147.759 Y369.435
    X-143.209 Y368.280
    X-138.685 Y367.037
    X-134.189 Y365.707
    X-129.724 Y364.291
    X-125.293 Y362.790
    X-120.898 Y361.205
    X-116.541 Y359.538
    X-112.089 Y357.728
    X-107.665 Y355.825
    X-103.270 Y353.831
    X-98.909 Y351.746
    X-94.583 Y349.570
    X-90.295 Y347.304
    X-86.049 Y344.951
    X-81.846 Y342.509
    X-77.690 Y339.982
    X-73.584 Y337.370
    X-69.529 Y334.675
    X-65.528 Y331.898
    X-61.584 Y329.041
    X-57.700 Y326.106
    X-53.876 Y323.095
    X-50.117 Y320.009
    X-46.423 Y316.850
    X-42.797 Y313.622
    X-39.241 Y310.325
    X-35.756 Y306.962
    X-32.346 Y303.536
    X-29.010 Y300.049
    X-25.751 Y296.503
    X-22.570 Y292.900
    X-19.463 Y289.245
    X-16.422 Y285.520
    X-13.451 Y281.728
    X-10.551 Y277.871
    X-7.726 Y273.951
    X-4.976 Y269.969
    X-2.303 Y265.928
    X0.290 Y261.830
    X2.801 Y257.678
    X5.230 Y253.474
    X7.574 Y249.221
    X9.832 Y244.920
    X12.002 Y240.576
    X14.084 Y236.190
    X16.076 Y231.765
    X17.976 Y227.304
    X19.785 Y222.810
    X21.502 Y218.285
    X23.125 Y213.733
    X24.653 Y209.156
    X26.088 Y204.557
    X27.427 Y199.939
    X28.672 Y195.306
    X29.816 Y190.659
    X30.869 Y185.985
    X31.830 Y181.287
    X32.698 Y176.567
    X33.473 Y171.827
    X34.155 Y167.072
    X34.742 Y162.303
    X35.234 Y157.523
    X35.631 Y152.735
    X35.934 Y147.943
    X36.140 Y143.148
    X36.252 Y138.353
    X36.269 Y133.562
    X36.192 Y128.778
    X36.032 Y124.115
    X35.782 Y119.450
    X35.441 Y114.784
    X35.008 Y110.120
    X34.484 Y105.461
    X33.869 Y100.810
    X33.163 Y96.168
    X32.366 Y91.540
    X31.479 Y86.927
    X30.502 Y82.333
    X29.435 Y77.759
    X28.280 Y73.209
    X27.037 Y68.685
    X25.707 Y64.189
    X24.291 Y59.724
    X22.790 Y55.293
    X21.205 Y50.898
    X19.538 Y46.541
    X17.728 Y42.089
    X15.825 Y37.665
    X13.831 Y33.270
    X11.746 Y28.909
    X9.570 Y24.583
    X7.304 Y20.295
    X4.951 Y16.049
    X2.509 Y11.846
    X-0.018 Y7.690
    X-2.630 Y3.584
    X-5.325 Y-0.471
    X-8.102 Y-4.472
    X-10.959 Y-8.416
    X-13.894 Y-12.300
    X-16.905 Y-16.124
    X-19.991 Y-19.883
    X-23.150 Y-23.577
    X-26.378 Y-27.203
    X-29.675 Y-30.759
    X-33.038 Y-34.244
    X-36.464 Y-37.654
    X-39.951 Y-40.990
    X-43.497 Y-44.249
    X-47.100 Y-47.430
    X-50.755 Y-50.537
    X-54.480 Y-53.578
    X-58.272 Y-56.549
    X-62.129 Y-59.449
    X-66.049 Y-62.274
    X-70.031 Y-65.024
    X-74.072 Y-67.697
    X-78.170 Y-70.290
    X-82.322 Y-72.801
    X-86.526 Y-75.230
    X-90.779 Y-77.574
    X-95.080 Y-79.832
    X-99.424 Y-82.002
    X-103.810 Y-84.084
    X-108.235 Y-86.076
    X-112.696 Y-87.976
    X-117.190 Y-89.785
    X-121.715 Y-91.502
    X-126.267 Y-93.125
    X-130.844 Y-94.653
    X-135.443 Y-96.088
    X-140.061 Y-97.427
    X-144.694 Y-98.672
    X-149.341 Y-99.816
    X-154.015 Y-100.869
    X-158.713 Y-101.830
    X-163.433 Y-102.698
    X-168.173 Y-103.473
    X-172.928 Y-104.155
    X-177.697 Y-104.742
    X-182.477 Y-105.234
    X-187.265 Y-105.631
    X-192.057 Y-105.934
    X-196.852 Y-106.140
    X-201.647 Y-106.252
    X-206.438 Y-106.269
    X-211.222 Y-106.192
    X-216.104 Y-106.022
    X-220.988 Y-105.753
    X-225.872 Y-105.385
    X-230.753 Y-104.916
    X-235.627 Y-104.348
    X-240.492 Y-103.680
    X-245.344 Y-102.912
    X-250.180 Y-102.046
    X-254.997 Y-101.081
    X-259.793 Y-100.017
    X-264.564 Y-98.857
    X-269.308 Y-97.601
    X-274.021 Y-96.249
    X-278.700 Y-94.803
    X-283.344 Y-93.264
    X-287.948 Y-91.633
    X-292.413 Y-89.945
    X-296.853 Y-88.165
    X-301.265 Y-86.294
    X-305.646 Y-84.332
    X-309.994 Y-82.280
    X-314.306 Y-80.140
    X-318.579 Y-77.911
    X-322.810 Y-75.596
    X-326.998 Y-73.194
    X-331.138 Y-70.709
    X-335.229 Y-68.140
    X-339.268 Y-65.490
    X-343.254 Y-62.759
    X-347.182 Y-59.950
    X-351.052 Y-57.065
    X-354.860 Y-54.105
    X-358.606 Y-51.073
    X-362.286 Y-47.969
    X-365.899 Y-44.798
    X-369.442 Y-41.559
    X-372.915 Y-38.257
    X-376.316 Y-34.892
    X-379.642 Y-31.469
    X-382.911 Y-27.976
    X-386.117 Y-24.411
    X-389.257 Y-20.776
    X-392.329 Y-17.073
    X-395.332 Y-13.304
    X-398.262 Y-9.470
    X-401.118 Y-5.574
    X-403.897 Y-1.618
    X-406.599 Y2.395
    X-409.221 Y6.464
    X-411.762 Y10.587
    X-414.219 Y14.759
    X-416.592 Y18.980
    X-418.879 Y23.247
    X-421.079 Y27.556
    X-423.190 Y31.906
    X-425.212 Y36.292
    X-427.144 Y40.714
    X-428.984 Y45.168
    X-430.732 Y49.650
    X-432.388 Y54.160
    X-433.951 Y58.692
    X-435.420 Y63.245
    X-436.809 Y67.883
    X-438.107 Y72.554
    X-439.311 Y77.255
    X-440.422 Y81.984
    X-441.438 Y86.738
    X-442.358 Y91.514
    X-443.182 Y96.309
    X-443.910 Y101.120
    X-444.540 Y105.944
    X-445.073 Y110.778
    X-445.508 Y115.620
    X-445.845 Y120.466
    X-446.084 Y125.313
    X-446.226 Y130.159
    X-446.270 Y135.000
    G0   Z5.000
    G0 X0.000 Y0.000
    G0Z5.000
    X0.000Y0.000
    M4
  15. Peter Van Der Walt
    Colors doesn't have significance. You will have to test
  16. Svechnikov Workshop
  17. Peter Van Der Walt
    Would you consider downloading and posting them as a Resource with a nice short writeup? Resources | OpenBuilds
    Just in case the original site ever goes down :)
  18. Svechnikov Workshop
    Here
  19. Peter Van Der Walt
    Thank you!!!!!!!!!!
    Svechnikov Workshop likes this.
