Blackbox Setup on a Rack & Pinion
Discussion in 'Controller Boards' started by Bigmontel, Jun 25, 2022.
  1. Bigmontel
    Bigmontel Well-Known
    Ok, so looking for some insight.
    Currently building a new 4836 rack & pinion CNC and I coming from an Openbuilds Workbee.
    I’m using my Openbuilds blackbox which I have working on the 4836RP.
    I have changed all GRBL settings to those recommended for my new machine and it jogs in all the proper directions and sounds normal until it builds a little speed and then it binds up stops and sounds like the cog is spinning. Then it’ll allow you to continue jogging and happens again with a little speed.
    This happens in all directions and on all axis’ except Z which is still leadscrew.
    I’ve been told the micro stepping needs to be adjusted to 1/32nds on X, Y1, and Y2.
    I know it’s possible on the blackbox after reading the docs, just not quite sure how to go about it. Seems like a risky procedure with the soldered mode caps.
    Anyone done this adjustment?
    No that would slow you down and also lower torque
    Leave it on 1/8th
    Stalling during a long move means you have Max Rate set too high in Grbl Settings. See the Grbl Wiki for the tuning procedure
  3. Bigmontel
    Ok, I’ll take a look at my max rates tomorrow. Thanks Peter.
  4. ARKHAN_74
    ARKHAN_74 New
    how to do Rack n pinion setting for Nema23 using Blackbox X32 ?? any video or guide pdf
    Grbl v1.1 Configuration - just calculate theoretical steps per mm based on your mechanicals, then fine tune using CONTROL > Wizards and tools > Calibration
    ARKHAN_74 likes this.
  6. David the swarfer
