BlackBox X32 CoreXY firmware?
Discussion in 'Laser Cutters' started by uverseman, Jul 31, 2023.
  1. uverseman
    uverseman New
    Where to find? Building a co2 laser, I have x32 with stock firmware. I want to find firmware to setup a CoreXY system, I am not too familiar with compiling, although if it's my only option I guess I can learn,
    but prefer one that all ready to flash my x32.
    Any suggestions or help appreciated.
  3. uverseman
    uverseman New
    wow that was fast response and an easy solution. Thanks for help. Appreciated.
  4. David the swarfer
    peter, do you have a list of the options to pick for a stock X32 build? I'd like to document it as a resource....
    3 axes, with Y set to Ganged on first tab
    On the plugins tab, enable SD
    Networking tab: set WebUI to V3 and enable the Telnet server for CONTROL
    That's about it.
    In the factory we use a backup image that also has the basic settings correct and has the v3 webui uploaded to SPIFFS so if its a clean flash expect to upload the WebUI and $4,5,6,10 etc would be on incorrect values (but fixed with a load of a machine profile from CONTROL)
