control software has disappeared. Problem Solved
Discussion in 'Control Software' started by donald k wilson, Dec 29, 2024.
  1. donald k wilson
    Hi all
    I have an unusual situation with the control software, it has disappeared from my list of installed apps, the program will not start. I downloaded a replacement file, attempted to install and got a message the control software could not be shut off, try closing manually which I can't find to stop. It does not show up in task manager and restarting the computer does not change the situation. Thoughts...?
    Thanks, dkw
  2. donald k wilson
    Hello again,
    quick update, I've found the file on my hard drives, it won't start and i can't delete.
    I'm not sure where to look for the open file...?
    thanks, dkw
    Unable to delete because its still running in the background.
    1) Check Task manager and kill any stuck ones
    2) Then try uninstall / delete type cleanup
    3) Then reinstall
  4. donald k wilson
    Hi Peter,
    I did all of that before I reached out.
    It does not show up in task manager, it has disappeared from the app manager list to uninstall/repair.
    I can't delete from the hard drive or reinstall, I get the file open error message shown above.
    Open builds used to start automatically when I turned on the computer, give a successful start message and sit in the active program tray on the toolbar, it is also no longer doing any of that.
    Can't delete it, can't reinstall it...
    thanks, dkw
    This message of yours
    Confirms its still running in the background
    If it wasnt running, you'd be able to delete above, so check again. Details tab, sort by Name
  6. donald k wilson
    Hi Peter,
    That was it, it didn't show up on the front page of task manager but it was there in the details. good to know...
    Back up and running, thank you so much!
    dkw
    Correct, because:
