Customize The Openbuilds Control Screen
Discussion in 'General Talk' started by William Otto, Jan 29, 2022.
  1. William Otto
    Is it possible/legal to customize the Openbuilds control screen? Specifically, under Gcode I want to keep from file and get rid of cam, fabber, carveco, lightburn, and vectric. Under tool on, I want to get rid of router, laser, plasma and coolant. Under tool off, I want to get rid of router. Above cam tools, I want to get rid of Fabber and Carveco. I also like to make a screen button for Go to predefined positions G28 and G30 as I make use of these on a daily basis. The things I want to get rid of are in the way and are often opened inadvertently, which is annoying. OB Control works well for me but I'd like to move the things I don't need out of the way.
    Yes and yes... Depending on your JavaScript skillset - either fork the project, or use a javacript Macro to make changes to the DOM
  3. William Otto
    Thanks, Mark!
  4. perks1018
    perks1018 New
    Once you've done that, would you mind making it available on Github? I don't need that other junk either.
