End stop Activation
Discussion in 'General Talk' started by Yves Beaulieu, Mar 16, 2024.
  1. Yves Beaulieu
    I am a new kid in the block and English is no t my natural language any way ...I have som issues with my limits switchs in Gbrl what are the command to activate them, note that i change the wireing 3 time and nothing do And please in Grbl wat the meaning of (Boolean and
    Mask) T.Y.
    Which controller do you have? And are you using OpenBuilds CONTROL?
    Mask = a setting that applies per-axis, boolean = true/false or enabled/disabled
  3. David the swarfer
    ChatGPT (free AI chatbot) does an excellent job of translating French to English and back. so you can type your question in french, have it converted, and paste the english here. Same going the other way, paste our english into chatgpt, then read the french.
    "ChatGPT (chatbot IA gratuit) fait un excellent travail de traduction du français vers l'anglais et vice versa. Ainsi, vous pouvez taper votre question en français, la faire traduire, et coller l'anglais ici. Il en va de même dans l'autre sens, vous pouvez coller votre anglais dans ChatGPT, puis lire le français traduit."
  4. Yves Beaulieu
  5. Yves Beaulieu
    Sorry about problems cause by my first message I did a reply but obviously didn,t go to the good place. That reply was...(my controler is Open Build control + Black Box X32 ). If you allow me there another question I can,t do a proper Homing here my set-up $22=1 $23=X_Y_Z=Max $24=25.00 $25=1500.00 $26=250 $27=3.00 $130=465.00 $131=617.00 $132=82.00 And my Micro switch are normaly Close Tank You very much. Merci Beaucoup Best Regard
    Make sure $5 is correct (use Troubleshooting tab to test switches by hand)
    What exactly happens?
  7. Yves Beaulieu
    Wel I crash few time. scrap 3 M.S, when the Z go up he stay there aprox 60 sec. and turn very slowly and finish the X axes and make a incomplete homing Best Regard Peter
    • Pictures of machine showing switches locations
    • full grbl settings backup for review (CONTROL > Grbl Settings tab > Backup Settings button)
    • Highly recommend using the better quality switches: Xtension Limit Switch Kit
  9. Yves Beaulieu
    ( $5=7)
  11. Yves Beaulieu
  12. Peter Van Der Walt
    You want $5=0 if all the switches are NC
  13. Yves Beaulieu
    Thank You Sir for your time and advise, realy apreciate
