Error when using comments
Discussion in 'Control Software' started by William Stickney, Aug 6, 2023.
  1. William Stickney
    I am currently using control software with the openbuilds blackbox which actually works very well except for one issue. If I include comments at the top of the file (in parenthesis) to tell me tool, stock size etc.. I continually get an error and end up removing the comments section before running the program.
    Is there a simple way to preserve the comments inside of my gcode files?
    Bill
  2. Alex Chambers
    Can you upload an example g-code file?
  3. William Stickney
    Here you go
  4. sharmstr
    Remove the inner parenthesis in the first line. As it is now grbl will consider it as
    Comment:
    (Tool: V-Bit (45.0� - 297/500")
    Garbage:
    - 0.594)
  5. William Stickney
    This is what I'm using;
    VCarve Desktop
    OpenBuilds GRBL (inches) post processor
    Is there a way to make this post processor send out the gcode in the correct format?
    The code is still giving me issues unless I remove the comments prior to running it. I will try to run it again with the comments to see if I can capture the actual error code.
    I would like to be able to use code with the comments as it is quite a time saver for me during job setup.
    Thanks for the help so far.
    Bill
    Check your Tool Library, seems the extra brackets comes from comments on the tool itself
    The invalid Degree character as well, cleaning up the tool library will help
    Comments by itself is allowed (Though semicolon lines are preffered to brackets, for example
    ;this is a comment
    you can use Brackets as well but make sure it only has one opening, and one closing bracket)
  7. William Stickney
    Thanks, I'll give it a shot later today and see what happens.
  8. William Stickney
    I think I may have figured this out.
    I tested it on one of the gcode files and it seemed to work so far. I'll be back if I have any issues with it.
    What I did was remove the line in the post processor that was telling it to write the first tool line in the g-code.
    Thanks for all the help.
    Bill
  9. William Stickney
    If you're interested, this is the post processor how I'm currently using it.
    Bill
    Shouldn't need to (no other reports), but just check your Tool Library - when you added the tool you used the "degree" character and added brackets it seems - and remove the Brackets from the descriptions all will be working fine with the standard post, and include the tool info (useful to know what bit the job was CAM'ed with)
