Gcode modifications
Discussion in 'General Talk' started by factory, Oct 27, 2024.
Tags:
  1. factory
    factory New
    I have a question about turning the laser head on and off during G0 transitions. My setup is Lead1515, BlackBox x32, OptLasers PLH3D-XT8. The BlackBox is connected to Lightburn where when I want to burn two simple objects during the transition between them the laser continues to work. I understand what the problem is, before each G0 command M5 should be generated and immediately after it M4. However, I wonder if there is any possibility to configure BlackBox so that it pauses the laser on G0? Or maybe there are other possible solutions apart from manual modification of gcode or through a script. I would be grateful for any help.
    Normally not like that no: should be M4 right at the start of the job, M5 all the way at the end. In between its G0 moves = off (travel), G1/2/3 moves = laser on (feed moves)
    Have a read (and check that you remembered to enable it) to learn how Grbl/grblHALs laser mode works https://github.com/gnea/grbl/wiki/Grbl-v1.1-Laser-Mode
  3. factory
    factory New
    Thank you for your quick reply ... I guess I didn't explain my problem well. When the $32=1 option is enabled and the project is started directly from Lightburn, the head works at maximum power immediately. I understand why it behaves like this - cgode starts with M4 and ends with M5. It ignores G0 as a transition between paths. The head responds well to M4 and M5 commands, turning the laser on and off, but I am unable to manage the head's power with Openbuilds Control (option from UI). It doesn't matter whether I choose 5% or 100%, the head always works at maximum power. Looking at the generated code from Lightburn, I only see commented lines like "; Cut @ 3500 mm/min, 20% power" Instead of M4 S200.Is there anything I can do to make the laser work properly?
  5. factory
    factory New
    I messed up at the first point ... I connected the head to Tool and not to PWM. Now everything works fine. Thanks for your help.
    Giarc likes this.
