GCODE Parser ] GCODE File (from gcode editor) sent to backend
Discussion in 'OpenBuilds Bug Report' started by dominic girard, May 8, 2023.
  1. dominic girard
    HI GUYS !
    I have a CNC with a controller however it only sends the code to the back end since we had a power outage
    this is my g code and in attenchement file you have my backup setting
    [11:11:09] [ connect ] Detecting Firmware: Method 2 (Ctrl+X)
    [11:11:09] [ ] Grbl 1.1g ['$' for help]
    [11:11:11] [ $$ ] $0=10 ;Step pulse time, microseconds
    [11:11:11] [ $$ ] $1=255 ;Step idle delay, milliseconds
    [11:11:11] [ $$ ] $2=0 ;Step pulse invert, mask
    [11:11:11] [ $$ ] $3=7 ;Step direction invert, mask
    [11:11:11] [ $$ ] $4=1 ;Invert step enable pin, boolean
    [11:11:11] [ $$ ] $5=0 ;Invert limit pins, boolean/mask
    [11:11:11] [ $$ ] $6=0 ;Invert probe pin, boolean
    [11:11:11] [ $$ ] $10=1 ;Status report options, mask
    [11:11:11] [ $$ ] $11=0.010 ;Junction deviation, millimeters
    [11:11:11] [ $$ ] $12=0.002 ;Arc tolerance, millimeters
    [11:11:11] [ $$ ] $13=0 ;Report in inches, boolean
    [11:11:11] [ $$ ] $20=0 ;Soft limits enable, boolean
    [11:11:11] [ $$ ] $21=0 ;Hard limits enable, boolean
    [11:11:11] [ $$ ] $22=0 ;Homing cycle enable, boolean (Grbl) / mask (GrblHAL)
    [11:11:11] [ $$ ] $23=0 ;Homing direction invert, mask
    [11:11:11] [ $$ ] $24=25.000 ;Homing locate feed rate, mm/min
    [11:11:11] [ $$ ] $25=500.000 ;Homing search seek rate, mm/min
    [11:11:11] [ $$ ] $26=250 ;Homing switch debounce delay, milliseconds
    [11:11:11] [ $$ ] $27=1.000 ;Homing switch pull-off distance, millimeters
    [11:11:11] [ $$ ] $30=1000 ;Maximum spindle speed, RPM
    [11:11:11] [ $$ ] $31=0 ;Minimum spindle speed, RPM
    [11:11:11] [ $$ ] $32=0 ;Laser-mode enable, boolean
    [11:11:11] [ $$ ] $100=320.000 ;X-axis steps per millimeter
    [11:11:11] [ $$ ] $101=320.000 ;Y-axis steps per millimeter
    [11:11:11] [ $$ ] $102=320.000 ;Z-axis steps per millimeter
    [11:11:11] [ $$ ] $110=2000.000 ;X-axis maximum rate, mm/min
    [11:11:11] [ $$ ] $111=2000.000 ;Y-axis maximum rate, mm/min
    [11:11:11] [ $$ ] $112=500.000 ;Z-axis maximum rate, mm/min
    [11:11:11] [ $$ ] $120=300.000 ;X-axis acceleration, mm/sec^2
    [11:11:11] [ $$ ] $121=300.000 ;Y-axis acceleration, mm/sec^2
    [11:11:11] [ $$ ] $122=300.000 ;Z-axis acceleration, mm/sec^2
    [11:11:11] [ $$ ] $130=380.000 ;X-axis maximum travel, millimeters
    [11:11:11] [ $$ ] $131=576.000 ;Y-axis maximum travel, millimeters
    [11:11:11] [ $$ ] $132=70.000 ;Z-axis maximum travel, millimeters
    [11:11:11] [ $$ ] ok
    [11:11:11] [ $I ] [VER:1.1g.20181112:]
    [11:11:11] [ $I ] [OPT:V,15,128]
    [11:11:11] [ $I ] ok
    [11:11:11] [ $G ] [GC:G0 G54 G17 G21 G90 G94 M5 M9 T0 F0 S0]
    [11:11:11] [ $G ] ok
    [11:11:12] [ connect ] Firmware Detected: grbl version 1.1g on COM8
    [11:11:34] [ GCODE Parser ] GCODE File (from gcode editor) sent to backend
    Have you tested your power supply?
    What version of CONTROL are you on?
  3. dominic girard
    hi the power suply are good and the controler are
    BlackBox Motion Control System
  5. dominic girard
    this is the 4x
    Still no reply to the very first question?
  7. dominic girard
    i use the same version openbuilds control v1.0.367
    Right, next up, you said
    But then posted the Serial log (no GCODE)
    Can you properly post the GCODE so we can check for you? Use the Upload a File button
  9. dominic girard
    the original question are why he send the code in backend ..
    but this is my file
    The frontend (GUI) sits on top of a backend (Server) that talks to your controller. Thats all exactly fine
    But your GCODE doesn't start running per your report.
    So either controller doesn't have power (confirmed)
    Grbl settings are wrong (But its not)
    or theres an issue with the gcode
    And you gcode contains an M6 on line 1, so its not Grbl Compatible. Use a Grbl Compatible CAM/Post please
    docs:software:overview [OpenBuilds Documentation]
  11. dominic girard
    the powersuply give 24.16V to the controler
    is it possible the controler was dead?
  12. dominic girard
    do you have a solution plz :/ i have some job :\
    thx you so much am wating your anser
  13. dominic girard
    other file without g6
  14. Peter Van Der Walt
    Do you have another computer to try? (Could be something PC specific, we know it works fine for everyone else)
    Do you have any firewalls, etc that could be blocking comms between frontend and backend?
  15. dominic girard
    I'll try thank you I'll get back to you
  16. David the swarfer
    gcode works ok for me
    but
    I predict you are going to have problems in the future because that Gcode has no header that sets the modes
    looks like metric code, so it should have at least
    G21 G90
    Gcode must always set the modes it expects because it cannot know what happened before it loaded.
    some macro or previous file may have used inch mode
    some macro or previous file may have set incremental mode
    and so on.
  17. dominic girard
    unt this time i need to try on other pc because i dont have any firewall and the only error i have are gcode send to backend ... i try this tomorow
  18. Peter Van Der Walt
    Not an ERROR, just a report that the frontend, sent the gcode to the backend for furthe processing. If nothing further happens, its a PC specific problem of some sorts
  19. dominic girard
    Hiii guys thank you soo much for your help!!
    After a fresh install of Windows all of cnc work
  20. dominic girard
    Good morning,
    I did one task that was fine after the same problem occurred.
    I tried with another computer and the problem presented itself as soon as I connected and pressed the play button
    after all of this test is it my controler ?
  21. Peter Van Der Walt
    I'd still say a PC problem of sorts. Did you reinstall anything else since it worked (firewall, 3rd party antivirus/antimalware, any other applications)
  22. dominic girard
    However I made no changes on the computer
  23. Peter Van Der Walt
    To really rule it out, do you have a different PC at hand you can do a quick test with? If it works on there, controller is fine
  24. dominic girard
    same problem at this time. i have try with my mac
  25. Peter Van Der Walt
  26. dominic girard
    after some hours of diag...
    some little piece of aluminium in drive motor connector .....
    so the controler fall in protection mode..
    thanks you soo much
    #26 dominic girard, May 18, 2023
    Alex Chambers likes this.
