Groves on the edges
Discussion in 'CNC Mills/Routers' started by mlowka, Apr 2, 2023.
  1. mlowka
    mlowka New
    Hi! I'm using 6mm drill, RPM 19000, feed 3000, cut depth 2mm. Separate finish last pass 0.5mm. material: mdf. I'm attaching a photo of the groves- what should I adjust? All screws are tightened- there are no looses on the machine.
  2. Christian James
    Christian James Journeyman
    You're using a 6mm "drill"?
  3. mlowka
    mlowka New
  4. Alex Chambers
    @Christian James, I'm guessing that's a translation problem, as there is no way the OP would have got the result he did with a drill bit.
    @mlowka did you mean "end mill"?
  5. mlowka
    mlowka New
    Yes 6mm end mill :)
  6. David the swarfer
    given that all axes are correctly adjusted and have no slop or backlash, I'd say this might be a bent leadscrew, research 'z axis wobble' in 3d printers.
